Gold Plated BNC Connectors
Old 11-11-2003, 12:14 PM   #1
4,851, Level: 16
Points: 4,851, Level: 16 Points: 4,851, Level: 16 Points: 4,851, Level: 16
Thanks: Gave 2, Got 14
Does anyone know a source of Gold Plated BNC connectors ?
I am looking for 'Male Crimp type' to make a customer RGBHV cable,
and
'Female bulkhead panel crimp' to make a wall plate.
Prefer not to solder (Crimping gives a better connection).
Russ !
Old 11-11-2003, 10:47 PM   #2
Exeter Man
Posts: n/a
Russ,
Give the following a try .....
http://www.vdctrading.com/
http://www.maplin.co.uk/
https://www.canford.co.uk/
http://custom1.farnell.com/cpc/Defau...ookie%5Ftest=1
Probably more links in the suppliers sticky.
Regards
