Mounting a PJ
Old 19-06-2009, 1:00 PM   #1
skydivemacca's Avatar
3,388, Level: 13
Points: 3,388, Level: 13 Points: 3,388, Level: 13 Points: 3,388, Level: 13
Thanks: Gave 52, Got 30
Mounting a PJ
Hello all
Looking back at some build pictures of my house, it's almost 99% certain that where I want to mount the projector is going to be directly between two joists.
As this means I wont be able to mount onto the joist itself, what are my other options?
I'd rather not put MDF or similar up on the plasterboard to meet the joists, as i want it to look as smooth and low mess as possible on the ceiling.
The PJ and mount don't seem over heavy - the PJ is an Optoma HD700x and the mount is this one - Do you think the plaster board could take it with suitable fixings? If so, what would those be?
Thanks for any help in advance
Old 19-06-2009, 1:05 PM   #2
6,583, Level: 19
Points: 6,583, Level: 19 Points: 6,583, Level: 19 Points: 6,583, Level: 19
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Thanks: Gave 516, Got 76
Re: Mounting a PJ
Look at my sig - mines been held up on just the plasterboard for nearly a year now - no problems!
