Hey, not quite sure where to post this but here goes.
ive been looking around the internet for ages but cant get a clear, simple answer.
Basicly i have 3 wall sockets in my room, well a single and a double.
VERY annoyingly, the double socket is now inaccessable due to being behind my bed on the opposite wall to all my equipment. ( and theres no other way to have the room)
Heres the thing, i need to run the following as i have a small home studio set up and home cinema set up.
ok so ..
home cinema..
37" LCD TV
AV Reciever
HDMI freeview box
PS3
Subwoofer
2 way switch box (untill i get my new reciever)
Computer / studio stuff..
PC
2 x 22" LCD monitors
Pair of studio monitors (speakers)
Mixing desk
Firewire interface
router
Phone base (landline)
and my macbook pro is in the post so ill need to be able to charge that too.. although i could probly use the ones behind my bed for things like that.
obviously my problem is i only have one accessible socket.
and ive just decorated litteraly 2 weeks ago, so obviously i dont want to be re-wiring.
Im guessing all that plugged in and running is going to be WAY too much right?
at the moment im just running all the home cinema stuff and bare essentials for the comp (pc, screens, and router)
and ive experienced no problems whatsoever
IS this to much? if yes any suggestions?
id like to say it wont all be on at once, but chances are at some point it will be,
thanks for any response
oh, and if it makes any differance.. i have run all of this equipment before using a combination of the single and double sockets with multiple 4-way extensions.
If i can use all this stuff in the single socket... it will run as follows..
3 way surge protected spillter, then the relevant amount of extentions run off.
thanks again!
