Belkin PureAV S-video to Scart & Audio lead - £1.99
Old 08-01-2009, 10:36 PM   #1
5,142, Level: 16
Points: 5,142, Level: 16 Points: 5,142, Level: 16 Points: 5,142, Level: 16
Thanks: Gave 146, Got 112
Ok, so there are bargains, then there are bargains, then there are stupid prices like this which make you think something has gone very wrong with the pricing system!
Genuine Belkin PureAV high quality SCART to S-Video 2 RCA, 1.2m cabes, RRP £25 selling for just £1.99 in Home & Bargain! I did a proper double take when I walked passed them today and thought it must be a price error, but sure enough that's the price. The raw materials alone must be worth more than that! Belkin : PureAV™ Scart To RCA/S-Video Cable 16'
So if you happen to be needing this cable you're in luck (or, even if you don't need one, as I told my wife when she asked me why I'd bought one, 'it'd be rude not to at that price'..) Get 'em while they're hot!
Old 09-01-2009, 11:20 AM   #2
2,111, Level: 10
Points: 2,111, Level: 10 Points: 2,111, Level: 10 Points: 2,111, Level: 10
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 18, Got 4
re: Belkin PureAV S-video to Scart & Audio lead - £1.99
have you got a link to the retailer?
Old 09-01-2009, 11:23 AM   #3
Senior Moderator
Flimber's Avatar
20,347, Level: 34
Points: 20,347, Level: 34 Points: 20,347, Level: 34 Points: 20,347, Level: 34
Activity: 38.9%
Activity: 38.9% Activity: 38.9% Activity: 38.9%
Thanks: Gave 2,926, Got 2,442
TJ Morris Limited
munmohan (11-01-2009), Spiderkid (10-01-2009)
Old 09-01-2009, 12:37 PM   #4
Uridium's Avatar
33,227, Level: 44
Points: 33,227, Level: 44 Points: 33,227, Level: 44 Points: 33,227, Level: 44
Activity: 23.5%
Activity: 23.5% Activity: 23.5% Activity: 23.5%
Thanks: Gave 527, Got 1,810
Saw these the other day and noticed it was actually written on packaging as S-video to Scart not t'other way round as you have listed.
Will it work both ways? Thought I'd mention it as the QED Scart to S-Video lead i used to use was directional and wouldn't work both ways. Beliive this is the case for most of these S-video > Scart cables.
Old 09-01-2009, 1:22 PM   #5
Senior Moderator
Flimber's Avatar
20,347, Level: 34
Activity: 38.9%
No. Some are switchable though, IIRC. You'd have to resolder this in a different arrangement to 'reverse' it, assuming you can get into the Scart plug.
Mike.
Old 09-01-2009, 1:57 PM   #6
Uridium's Avatar
33,227, Level: 44
Activity: 23.5%
Maybe need to amend the title of thread then as this is definitely an S-video to Scart lead not Scart to S-video as per thread title
Old 09-01-2009, 9:49 PM   #7
Dave's Avatar
27,069, Level: 40
Points: 27,069, Level: 40 Points: 27,069, Level: 40 Points: 27,069, Level: 40
Activity: 8.0%
Activity: 8.0% Activity: 8.0% Activity: 8.0%
Thanks: Gave 1,682, Got 2,205
Done.
Old 10-01-2009, 12:22 PM   #8
5,142, Level: 16
Re: Belkin PureAV S-video to Scart & Audio lead - £1.99
Cheers for pointing that out. I hadn't realised they were directional! Still a bargain any which way they work!
Old 10-01-2009, 5:17 PM   #9
Chris Muriel's Avatar
15,697, Level: 30
Points: 15,697, Level: 30 Points: 15,697, Level: 30 Points: 15,697, Level: 30
Activity: 12.1%
Activity: 12.1% Activity: 12.1% Activity: 12.1%
Thanks: Gave 510, Got 629
In some areas or towns they're called Quality Save; just picked up one in Sale, Cheshire at store of that name.
Chris Muriel, Manchester
Old 11-01-2009, 1:07 PM   #10
Obfski's Avatar
2,998, Level: 12
Points: 2,998, Level: 12 Points: 2,998, Level: 12 Points: 2,998, Level: 12
Thanks: Gave 52, Got 13
Also in "Home Bargains" in Hull (and wherever else their stores are presumably)
Old 12-01-2009, 5:04 PM   #11
5,142, Level: 16
Just to update this thread, I checked back in to the same store today (called 'Home Bargains' in Liverpool) and found a Belkin PureAV 'Universal DVD connection kit' for just £1.99!
Basically this consists of the following components, each of which is worth well over £1.99 in its own right.
Switchable SCART adaptor
PureAV
3.6m composite video cable
Belkin : Blue Series Composite Video Cable
3.6m S-Video cable
Belkin : Blue Series S-Video Cable
3.6m 3.5mm to 2 RCA audio cable
All good quality cables at one stupidly low price!
Chris Muriel (13-01-2009)
Old 13-01-2009, 10:57 PM   #12
15,697, Level: 30
Activity: 12.1%
Now bought 2 of these DVD connection kits from my local Quality Save.
Thanks for the alert.
Old 13-01-2009, 11:53 PM   #13
5,142, Level: 16
No problem, got one myself and am going to go back for another kit. It really would be rude not to at that price..
Old 16-01-2009, 10:41 PM   #14
janz70's Avatar
2,539, Level: 11
Points: 2,539, Level: 11 Points: 2,539, Level: 11 Points: 2,539, Level: 11
Thanks: Gave 22, Got 9
got one of each - just in case
bargain greeter
