Panasonic TH-42PZ82B £799 Comet
Old 11-07-2008, 2:17 PM   #1
12,206, Level: 26
Points: 12,206, Level: 26 Points: 12,206, Level: 26 Points: 12,206, Level: 26
Thanks: Gave 56, Got 81
http://www.comet.co.uk/shopcomet/pro...NIC-TH-42PZ82B
bigcoralboy (14-07-2008)
Old 20-07-2008, 10:49 AM   #2
3,225, Level: 13
Points: 3,225, Level: 13 Points: 3,225, Level: 13 Points: 3,225, Level: 13
Thanks: Gave 11, Got 9
Re: Panasonic TH-42PZ82B £799 Comet
Originally Posted by milesr3 View Post
I saw this in Comet today whilst looking at the Freesat panel.
I threw me too.
I assumed I'd be able to do a compare and contrast online - nope; Panasonics site makes no mention of it.
Price-wise it's comparable to the TH-42PZ80B.
Is it a model designation specifically produced for certain retail outlets?
It looks virtually identical to the 81B.
Clearly it won't have Freesat and the only difference on the stickers was the lack of intelligent frame creation.
Can anyone shed any light?
TIA.
guh.
Old 20-07-2008, 6:33 PM   #3
Rob100's Avatar
12,167, Level: 26
Points: 12,167, Level: 26 Points: 12,167, Level: 26 Points: 12,167, Level: 26
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 88, Got 236
Comet's specs say that it doesn't support HDCP Don't believe it for one minute.
I wonder if it supports 1080p24 and refreshes correctly at a multiple of 23.976Hz?
Good price.
Old 20-07-2008, 8:36 PM   #4
12,206, Level: 26
FWIW the salesperson I spoke to said it was exactly the same as the 81B and 85B, but in a different surround, specific to Comet. I did find the 85B as well for £899 (in Currys IIRC) and that would have been where I had spent my money, but I ended up getting a Toshiba 46XF355DB instead for £799 in Comet.
Old 21-07-2008, 10:30 AM   #5
4,367, Level: 15
Points: 4,367, Level: 15 Points: 4,367, Level: 15 Points: 4,367, Level: 15
Thanks: Gave 13, Got 13
I have one of these and I'm pretty sure it's just a rebadged 42PZ80B. Possibly the only difference is that the lower bezel is black. Whereas on most of the 80Bs I've seen it's silver.
This was actually the reason I ended up getting it - the good price and I didn't like the two tone effect on the 80Bs I'd seen.
Mac.
Old 21-07-2008, 11:37 AM   #6
smashed's Avatar
6,741, Level: 19
Points: 6,741, Level: 19 Points: 6,741, Level: 19 Points: 6,741, Level: 19
Thanks: Gave 177, Got 167
£711 at Laskys....which is owned by comet.
Use code JULPANA
http://www.laskys.com/tv_and_dvd/pla...h_42pz82b.html
Old 29-07-2008, 8:32 PM   #7
MOOGLEYS's Avatar
2,768, Level: 12
Points: 2,768, Level: 12 Points: 2,768, Level: 12 Points: 2,768, Level: 12
Thanks: Gave 50, Got 28
I have this TV the difference is it has a black bottom instead of silver it also has 100hz double scan. Its an exclusive to the comet group. Its a fantastic Tv. I went from a 1080p 42" X3030 toshiba and the difference is amazing. The sticker around the surround of the Tv claims 24fps, I havent noticed any judder at all in either Blu-ray or Hd dvd films.
Old 04-02-2009, 11:08 PM   #8
2,083, Level: 10
Points: 2,083, Level: 10 Points: 2,083, Level: 10 Points: 2,083, Level: 10
Please tell me, does this TV support full 1900*1080?
i read mixed reviews and some say its .... * 768
Old 05-02-2009, 9:36 AM   #9
oj0 oj0 is offline
oj0's Avatar
1,992, Level: 10
Points: 1,992, Level: 10 Points: 1,992, Level: 10 Points: 1,992, Level: 10
Thanks: Gave 42, Got 61
It is the same spec as the pz80 except it is exclusive to Comet and Laskys and has a black surround. Has all of the same features including being 1080p.
HTH
Ben
Old 05-02-2009, 12:03 PM   #10
3,460, Level: 13
Points: 3,460, Level: 13 Points: 3,460, Level: 13 Points: 3,460, Level: 13
Thanks: Gave 125, Got 36
Next time you are in the shop ask him/her to show you the Freesat HD channels via the built in tuner (like the PZ81B) or how to select IFC (like the PZ85B). Methinks they'll struggle! As others have said, this is a rebadged PZ80B. It is neither an 81 nor an 85, both have different features.
It is however a top plasma. Isn't there an earlier post saying John Lewis are doing it for £699 (with their 5-year gntee)?
Old 05-02-2009, 12:07 PM   #11
3,712, Level: 14
Points: 3,712, Level: 14 Points: 3,712, Level: 14 Points: 3,712, Level: 14
Thanks: Gave 13, Got 5
Comet are crafty beggars - this is a re-badged PZ80. Means they don't have to price match. Has been discussed previously in the plasma section
