Originally Posted by ufitsy How does this compare to the Dell S2409W at £195 please? |
I have both and used them on an XBOX360, Vista media center with BR/HD and on a desktop PC.
For XBOX360 and Media centre at 10ft, the Dell is very good, mainly due to its native 1080p panel. Image is sharp and not soft where obvious multi stage scaling has taken place. However, colours, posterisation and off axis viewing are only good in my opinion.
For desktop PC use at 2ft, with occaisional media center (on PC) use the Yuraku is significantly better at colour, posterisation and off-axis viewing. Again, the image is very sharp despite the reduced distance and I have to admit that even though there is some scaling (it's 1920x1200) I can't really see a huge drop in image quality. However, you must balance this up with the fact that the panel type fitted in the Yuraku can and does vary so you may not get one of the latest panels. You should also consider that many of the badged Yurakus have similar panel type variability and several have no HDCP.
