AVF Deal Dark Knight home cinema artwork - special discount for AVForums members
Old 09-09-2012, 10:12 AM   #1
Thanks: Gave 6, Got 9
Dark Knight - Joker Digital Artwork by Andrew Timbs
For me, this was the stand out scene from the Dark Knight. It was a moment which brought the tension to its highest level and captured Heath Ledger's brilliant portrayal of the insane villain perfectly. The sound drops to a deadly silence where you could here a pin drop in the cinema, only the Jokers hair flicking in the wind. The Joker, the Dark Knight's perfect nemesis has won the battle leaving Batman an impossible choice of rescuing 'Gotham's saviour' Harvey Dent or childhood sweetheart Rachel Dawes.
This drawing is completely unique and stylized in a way that will not be found anywhere other than Movie Art Prints. It will look amazing in your home cinema.
Using the latest digital vector illustration programs, Movie Art Prints specialise in bringing your favourite film scenes and characters to your living room or home cinema. All artwork is meticulously hand drawn on screen and no digital manipulation of an original image is used.
AVForums members will receive a 10% discount on all artwork. Please reply to this thread to receive the special promotion code. All orders have free UK delivery.
Dark Knight - Joker is available in a selection of materials and sizes up to a massive 2m x 1m to fit perfectly to your available space.
MaterialDimensionsNormal PricePrice for AVForums members
Foamboard 5mm100cm x 50cm£59.99£53.99
Foamboard 5mm150cm x 70cm£79.99£71.99
MDF 18mm100cm x 50cm£99.99£89.99
Canvas100cm x 50cm£99.99£89.99
Canvas150cm x 70cm£149.99£134.99
Canvas200cm x 100cm£199.99£179.99
For further details on how the vector artwork is produced and to order, please visit MOVIE ART PRINTS
This offer on the Dark Knight Joker drawing will run through to the end of September.
Dark Knight home cinema artwork - special discount for AVForums members-joker.jpg   Dark Knight home cinema artwork - special discount for AVForums members-joker-vector.jpg   Dark Knight home cinema artwork - special discount for AVForums members-joker-wire.jpg
bootstrapwill (09-09-2012), Jenz (10-09-2012), Stuart Wright (09-09-2012)
Old 09-09-2012, 11:33 AM   #2
bootstrapwill's Avatar
Thanks: Gave 33, Got 16
Thanks, they look great.
Old 09-09-2012, 11:36 AM   #3
Dan201's Avatar
Thanks: Gave 364, Got 117
Looks good. Although my 2 favourites from the site are different sizes which means they can't be put next to each other. Shame.
AJ Timbs (09-09-2012)
Old 09-09-2012, 12:17 PM   #4
Hi Dan.
If you let me know which drawings are your favourite then there may be a way I can edit the drawings to be exactly the same size.
Dan201 (09-09-2012)
Old 09-09-2012, 5:27 PM   #5
Thanks: Gave 4, Got 50
Some of the artwork is amazing. I'll be saving up until I can buy 4/5 at once otherwise the room wouldn't look right.
Great job
Old 09-09-2012, 7:02 PM   #6
Thanks: Gave 86, Got 35
Will be saving up for one of these, they look great and I would appreciate a code.
Old 09-09-2012, 8:44 PM   #7
Dazza's Avatar
Thanks: Gave 23, Got 52
Fantastic scene, superbly captured
Old 10-09-2012, 10:36 AM   #8
Thanks: Gave 1, Got 11
Does look good, In the middle of trying to move house so don't want to put an order in yet - but could you send me a code so I can get a couple when I get settled in.
Old 10-09-2012, 11:22 AM   #9
Conspicuous Member
mooperman's Avatar
Thanks: Gave 2,992, Got 930
does the 10% apply to all bits on your site or just the dark knight?
Loving the teenwolf one!
Old 10-09-2012, 11:25 AM   #10
The 10% applies to everything on the website. I will pm you with the code.
mooperman (10-09-2012)
Old 10-09-2012, 12:10 PM   #11
MIghtyG's Avatar
Thanks: Gave 191, Got 636
Think I might just need a few prints to finish off my man cave, please send me a code!
Old 10-09-2012, 3:07 PM   #12
Thanks: Gave 11, Got 10
Just moved into new house and would appreciate code; artwork looks superb, looking for something like this for my cinema/games room but (sorry for the stupid question) what is the best method of fixing the foamboard panels?
Old 10-09-2012, 3:20 PM   #13
How to fix foamboard prints to the wall
There are two ways of fixing foamboard prints to the wall. Firstly, the foamboard material is very lightweight so can easily be fixed directly to the wall using velcro pads in each corner (I add an extra one to the top and bottom centre of the drawing just to be sure). The downside to this method is the damage it can cause to wallpaper. The second method is to frame the drawing. I have done this with my signed Freddy Krueger drawing. Obviously there is an extra cost to this but a frame does set off the drawing nicely and because they are printed on high gloss material, there is no reason to cover them with glass (which will save you a considerable amount). They are printed in UV ink so don't worry about fading.
PKtheDJ (10-09-2012)
Old 10-09-2012, 4:17 PM   #14
Dan201's Avatar
I have used these on wallpaper without a problem. They can hold quite a lot of weight too!
Command Medium Picture Hanging Strips .5"X2.75" 3 Sets/Pkg-white: Amazon.co.uk: Kitchen & Home
AJ Timbs (10-09-2012), PKtheDJ (10-09-2012)
Old 10-09-2012, 4:35 PM   #15
enigma1701's Avatar
Thanks: Gave 42, Got 84
Fantastic looking! Can I have a code please?
Old 10-09-2012, 7:24 PM   #16
J-a-m-e-s_7's Avatar
Thanks: Gave 28, Got 74
Hi, love some of the prints i've seen. Could you send me a code as i am contemplating a purchase. Also, i was wondering whether you could produce some custom prints of a few images i like. If you could let me know that would be great
Regards
James
Old 10-09-2012, 8:16 PM   #17
Thanks: Gave 44, Got 41
I'm in the same boat as meduk1.
Can you PM me a code to use in a couple of months once I have moved in?
Old 10-09-2012, 10:34 PM   #18
Kampione's Avatar
Thanks: Gave 9, Got 4
Could i have the code please? Really like the style and size of these
Old 11-09-2012, 1:16 AM   #19
Thanks: Gave 42, Got 43
Could I have a code please.
Old 11-09-2012, 4:55 PM   #20
Nevaborn's Avatar
Thanks: Gave 105, Got 377
Love the Batman Gotham city picture its perfect.
The Gandalf Vs Balrog is brilliant too.
Would love a code to use later down the line once ive saved enough for these beauties.
Would also like to know if you can do custom work.
Old 11-09-2012, 9:07 PM   #21
LicensedTaximan's Avatar
Thanks: Gave 168, Got 212
Just to let you all know you can buy these hanging strips in Homebase usually displayed on their own "Command" retail displays.
I bought several different sized types of their products on Homebases 15% off promotional weekends, they have several of these each year. "Command" also do picture hanging hooks as well. They are primarily meant for painted walls so I can't comment on their effectiveness on wallpaper. But on painted walls when you want to remove the strips just follow the instructions and no marks should appear and no paint should be removed.
Love the prints by the way , Unfortunately I just don't have anywhere to hang them.
AJ Timbs (11-09-2012)
Old 13-09-2012, 1:26 PM   #22
Dan201's Avatar
I received my order from Movie Art Prints this week and Ive just put them up. I went for the foamboards with a sand laminate.
Ive added a few pictures to my living room thread which can be found in my signature.
AJ Timbs (13-09-2012)
Old 18-09-2012, 4:45 PM   #23
MikeyDave's Avatar
Thanks: Gave 9, Got 3
Will look good in my Cinema/gaming room
Old 18-09-2012, 11:29 PM   #24
Restricted Member
this looks amazing sign me up for the 10% discount code please
Old 19-09-2012, 4:16 AM   #25
Mr Regan's Avatar
Thanks: Gave 143, Got 45
Can you pm me a code please,
Old 22-10-2012, 10:28 PM   #26
NWhiteley's Avatar
Thanks: Gave 377, Got 92
Hi, is this offer still available?
Old 04-12-2012, 8:04 AM   #27
Thanks: Gave 25, Got 18
I am interested in this... can I have a code as well please?
Old 09-01-2013, 3:58 PM   #28
ban me if you like, but someone is going to print this out poster size
Old 09-01-2013, 4:13 PM   #29
If someone wants to print a pixelated copy out at A3 and stick it on their bedroom wall with blu tack then so be it. Or, they could order a professionally printed and mounted piece of artwork up to two metres in length and hang it pride of place on their wall.
Old 09-01-2013, 8:22 PM   #30
I agree with you 100%
