panny 50 G10 - £799
Old 20-08-2009, 3:47 PM   #1
7,683, Level: 20
Points: 7,683, Level: 20 Points: 7,683, Level: 20 Points: 7,683, Level: 20
Thanks: Gave 55, Got 82
panny 50 G10 - £799
Saw these in cosco, not sure if it is a bargain as not on the lookout for a new plasma, but seems good. Comes With Cosco top notch 5 year warranty.
Old 21-08-2009, 8:34 AM   #2
3,764, Level: 14
Points: 3,764, Level: 14 Points: 3,764, Level: 14 Points: 3,764, Level: 14
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 5, Got 8
Re: panny 50 G10 - £799
Is that meant to be costco?
Is that including or excluding VAT?
Old 21-08-2009, 8:41 AM   #3
7,683, Level: 20
yes
not sure only glanced at it as I walked past.
I know they do a very good 5 year warranty, as I bougth my PZ there.
Old 21-08-2009, 10:19 AM   #4
40,074, Level: 48
Points: 40,074, Level: 48 Points: 40,074, Level: 48 Points: 40,074, Level: 48
Activity: 9.8%
Activity: 9.8% Activity: 9.8% Activity: 9.8%
Thanks: Gave 1,624, Got 838
I suspect that's excluding VAT, not bad though with a 5 yr guarantee!
Old 24-08-2009, 9:37 AM   #5
3,460, Level: 13
Points: 3,460, Level: 13 Points: 3,460, Level: 13 Points: 3,460, Level: 13
Thanks: Gave 125, Got 36
A quick word on the warranty - I understand that it only applies if you are a Costco member. If you are normally no probs, but if you join just to buy the tele you'll need to figure 5 years membership costs into the equation.
Old 24-08-2009, 12:06 PM   #6
3,764, Level: 14
Activity: 1.4%
phoned my local costco who said it is £1035 including VAT
