Bush BD01 Blu-ray Player £77
Old 25-05-2009, 7:38 PM   #1
Stuart's Avatar
28,730, Level: 41
Points: 28,730, Level: 41 Points: 28,730, Level: 41 Points: 28,730, Level: 41
Activity: 5.3%
Activity: 5.3% Activity: 5.3% Activity: 5.3%
Thanks: Gave 906, Got 2,604
Thanks to member novimihai for spotting this
BUSH BD01 BLU RAY DISC PLAYER DVD WMA MP3 JPEG REFURB on eBay, also Region 2 DVD Players, DVD Players, DVD Home Cinema, Consumer Electronics (end time 05-Jun-09 11:08:39 BST)
This can be converted to a Region A machine but the remote will become useless and you'd need a universal remote. See the below link for more info:
http://www.avforums.com/forums/blu-r...ml#post8800379
I've been using one for several months and it hasn't missed a beat with Region A discs. PQ and AQ every bit as good as my Panny
PS I've been using my Harmony One to control it with no problems
mckee74 (28-05-2009), taffster1967 (13-04-2010)
Old 27-05-2009, 8:23 PM   #2
mckee74's Avatar
6,621, Level: 19
Points: 6,621, Level: 19 Points: 6,621, Level: 19 Points: 6,621, Level: 19
Activity: 7.2%
Activity: 7.2% Activity: 7.2% Activity: 7.2%
Thanks: Gave 211, Got 285
Re: Bush BD01 Blu-ray Player £77
Does anyone have this? Is it any good? Very much like the idea of having a Region A player but it sure is ugly.
Old 28-05-2009, 12:59 PM   #3
toddy28's Avatar
8,572, Level: 22
Points: 8,572, Level: 22 Points: 8,572, Level: 22 Points: 8,572, Level: 22
Activity: 29.9%
Activity: 29.9% Activity: 29.9% Activity: 29.9%
Thanks: Gave 88, Got 166
wont play all blu-rays as you cant update the firmware i would not bother with this player at all even at £77 i was thinking about it as a region a player but after reading the owners thread i changed my mind not worth importing films if they might not play
Old 28-05-2009, 1:01 PM   #4
Stuart's Avatar
28,730, Level: 41
Activity: 5.3%
Since I converted mine to Region A, it's played everything flawlessly, well A or Free titles obviously.
And as it effectively becomes a US Insignia player, I presume future updates will be possible.
Old 13-04-2010, 9:53 AM   #5
642, Level: 5
Points: 642, Level: 5 Points: 642, Level: 5 Points: 642, Level: 5
Activity: 1.2%
Activity: 1.2% Activity: 1.2% Activity: 1.2%
Thanks: Gave 13, Got 1
hi there just a quick question after appliying the firware update for the insignia will it still play normal dvd's
thanks
Old 13-04-2010, 10:56 AM   #6
mckee74's Avatar
6,621, Level: 19
Activity: 7.2%
It will play normal DVD's, but only Region 1 DVD's as for all intents and purposes once you apply the firmware it is a COMPLETELY American player.
On a side note, I can't recommend it enough. A Region A player that bistreams TrueHD and DTS-HD MA for less than £80 is just a great deal. Picture quality is excellent.
Only other thing, once you do apply the firmware it messes up the remote - play becomes fast forward, 1 becomes play etc - so the only real stumbling block is I'd advise you have a Harmony remote or something of it's ilk in order to use it unless you have the patience to work out the buttons!
Old 13-04-2010, 11:43 AM   #7
642, Level: 5
Activity: 1.2%
Talking
thanks my friend ,you wouldnt happen to know if the harmony 515 would do the trick would you
Old 13-04-2010, 1:25 PM   #8
mckee74's Avatar
6,621, Level: 19
Activity: 7.2%
I can't imagine any reason why it wouldn't. I have the Harmony One but as far as my knowledge goes, they all still use the same database. If you should get one, let me know as I still have the model number that the Bush BD01 "becomes" once you update the firmware somewhere.
Old 13-04-2010, 1:41 PM   #9
642, Level: 5
Activity: 1.2%
Thumbs up
thankyou
Old 13-04-2010, 2:19 PM   #10
mckee74's Avatar
6,621, Level: 19
Activity: 7.2%
Knew I had it somewhere, the player it becomes is the Insignia NS-2BRDVD and the firmware can be found here:
Insignia NS-2BRDVD Blu-Ray Player Firmware Update - Community@Insignia
Old 13-04-2010, 4:19 PM   #11
642, Level: 5
Activity: 1.2%
Thanks mckee
Old 13-04-2010, 4:22 PM   #12
mckee74's Avatar
6,621, Level: 19
Activity: 7.2%
No worries. Welcome to the forum by the way.
Old 13-04-2010, 5:01 PM   #13
642, Level: 5
Activity: 1.2%
thankyou for your help until i manage to get hold of a remote for this i dont suppose you are aware of what the current buttons are do you,thanks
Old 13-04-2010, 5:15 PM   #14
mckee74's Avatar
6,621, Level: 19
Activity: 7.2%
I must admit I've never used the remote myself, but I see here on the owners thread some kind soul listed the commands so guessing this list is correct:
http://www.avforums.com/forums/blu-r...thread-34.html
