Downlighters in Celotex
We are about to build a kitchen extension with a pitched internal ceiling. To comply with building regs, the voids between the joists are to be filled with two layers of Celotex insulation.
We wanted to install downlighters in the pitched ceiling, but there is obviously a fire risk or lamp failure because of the insulation. Now I know you can get fire retardent downlighters, but there is obviously an issue with heat loss, and I don't think the building inspector will allow me to cut away the celotex around the downlighter. I've done some research and there is a standard called 'IC Housings' (Insulation Contact), but I can't see of many fittings complying with this standard (except this one CS5-IC - Photonstar Lighting - Performance Ecolighting). Has anyone had this problem or knows of a solution?
Sony KDL-46X2000. Sky HD. Sony BD-S550 & STR DG820. HTPC - Antec Max with iMon RM200 remote, E8200, Asus P5Q mb, 4gb ddr2 6400, Gib 8600gs, LG GGC-H20L, Vista 64, Windvd 9 plus
