3.5 million visitors each month
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Star Wars: The Clone Wars Blu-ray ReviewPublic Enemies - Original Motion Picture Soundtrack CD ReviewAudition Blu-ray ReviewPolice Story Blu-ray ReviewYear One Blu-ray Review
The Living Dead At Manchester Morgue Blu-ray ReviewPublic Enemies Blu-ray ReviewGojira Blu-ray ReviewHalloween II Original Motion Picture Score - Expanded 30th Anniversary Edition CD ReviewStar Trek - Complete Original TV Show Season 2 Blu-ray Review
The long road to home cinema heaven diesel Home Cinema DIY 193 30-09-2009 1:16 PM
The Awkward Lounge and a Bang-For-Buck Home Theatre wild_quinine Home Cinema DIY 5 27-04-2009 9:53 PM
How do I get fence panels home? RockStrongo General Chat 38 24-04-2009 9:11 AM
Anyone got an air conditioning unit at home? dcoop General Chat 29 23-04-2009 4:39 PM
Old 23-04-2009, 8:35 PM   #1 (permalink)
Thanks: Gave 7, Got 0
Home Automation help
Hi to all
I am in the process of building a new 3 bedroomed detached house in Gloucestershire and want to try and impliment a reliable home automation system in it to control as much as i can, I am having to wire from scratch so installation will be simple, but need to decide on what system to go for-
Ideally I would like it to be controlled via stratigically placed inteligent control panels with some integration with a server to allow things like blue tooth control from my I phone or remote control say whilst on holiday- I am prepared to spend a bit of time effort and money to get this right, as once its istalled there is no going back
Any help would be warmly recived and i would be happy to share experiences with like minded people on the site to try and iron out bugs in systems
Adrian
AdrianA1 is offline   Reply With Quote
Old 23-04-2009, 10:10 PM   #2 (permalink)
Thanks: Gave 18, Got 20
Re: Home Automation help
Macintosh Home Automation and Control Server
RipMaster is offline   Reply With Quote
Old 24-04-2009, 8:39 AM   #3 (permalink)
Thanks: Gave 1, Got 13
In reality most manufacturers will allow you to control your home from either a mobile phone or via the internet. You would be best having a chat with someone to work out your options - how many rooms of audio distribution do you want, how many of HD video, what else electrical do you want to control i.e. lighting, gates, sprinklers, blinds, heating etc etc
If you spend a lot of time away from home then incorporating intruder alarms and CCTV might provide great peace of mind.
The sky is the limit with these things!
There are a number of manufacturers you could look at Crestron, AMX, Control4 etc. Different ones will do different things for different budgets with differing amounts of style and functionality.
DaveChester is offline   Reply With Quote
Old 25-04-2009, 3:08 PM   #4 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,328
There are lots of options from home brew server software through to pro systems the thing you really need to get right at this stage is the infrastructure. What systems are you interested? Intelligent Lighting and heating? CCTV? TV and video distribution? Audio distribution? How much do you want to control from outside the property?
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
Old 19-05-2009, 12:46 PM   #5 (permalink)
Hi there,
You need to consult a professional to ensure that you integrate the right type and amount of cabling around the property.
To do this is quite cheap and you can then decide what to hang on the end of the cables at a later date.
Most control, audio and video can be conducted down cat5e, Coax and speaker cable. I have been recently introducing Fibre optic networks into properties as it is nowhere near as expensive as it used to be. High def can be transmitted long distance without problems using fibre.
I used to work as a project manager for a large custom install company in London and set-up on my own at the beginning of this year. I generally install Control4 wherever possible as it is solid and cheap to implement. I currently have several Control4 projects installed and in development.
I am in the process of setting up my website and setting up on AV forums as an assured advertiser. In the meantime please post any questions that you may have and I will help wherever i can.
Karl Melkerts.
Twisted Pear is offline   Reply With Quote
AdrianA1 (28-05-2009)
Old 28-05-2009, 9:35 PM   #6 (permalink)
Hi Karl
Thanks for the good advice, my property is at first floor joists at the moment so i have lots of time to decide on what I want
As I may have already said- I want to be able to control some things whilst away from the house via a router/internet, and also be able to automate a some of the heating/ventillation in order to make the house more economoicle to run.
I want to use cat5 whereever possibel and it was my intention to look at some systems including control 4 as it seems to be good value and reliable
Thanks again for you comments any thing else i can think of I may get back to you
Good luck with your new venture- where are you based??
Adrian
Old 03-06-2009, 8:41 AM   #7 (permalink)
Hi Adrian
Feel free to take a look at our website. We have some case studies which might be of interest.
We operate nationally so location would not be a problem.
Any questions or anything just drop me a line or contact via the website.
automation, home
