Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Galaxy Quest Blu-ray ReviewMy Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray Review
North By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray Review
Sony HT-DDWG800 Home Theatre System *Part 2* RottenFox All-in-one Systems 620 Yesterday 2:34 PM
Onkyo HTX22HD Integrated amp/speaker system Zeromajor All-in-one Systems 1004 15-04-2009 11:06 AM
Choices UK Spring clearout - PS3/X360/Wii/PS2/DS/PSP Superman86 Gaming Bargains and Discount Codes 14 10-04-2009 3:55 PM
Second hand Cambridge Audio separates system gazzawales Hi Fi Systems and Separates 2 10-04-2009 7:37 AM
For Sale : XBOX 360 PRO System, with 2 games!! monkeyboyv1 Xbox 360 Classified Adverts 13 09-04-2009 11:36 AM
Old 09-04-2009, 2:49 PM   #1 (permalink)
Thanks: Gave 1, Got 0
Rako lighting system - choice of dimmers?
Am thinking about installing a Rako lighting system in my house. I have a problem deciding which dimmer to use for the ceiling lights on the ground floor. Ideally would use the Rako pill in the light switch back box. BUt is it right that the pill does not work with energy saving bulbs (even dimmerable ones like Megaman)?
If that is the case, then other option is to wire in-line dimmer into circuit in ceiling void. Problem here is that dimmer is about 5cmx3cm. Is there any way a hole big enough to access ceiling void and insert dimmer can be made but still covered over by a standard ceiling light fitting? Unfortunately I cannot get access to ceiling void from above.
Would be very grateful for any suggestions. Cheers.
TIm.
Tim54 is offline   Reply With Quote
Old 09-04-2009, 3:17 PM   #2 (permalink)
Thanks: Gave 6, Got 6
Re: Rako lighting system - choice of dimmers?
rako do a dimmer for megaman CFL
Rako RDL500 CFL - Megaman CFL In Ceiling Light Dimmer - Rako Wireless Lighting Controls | uk online shop
Size (H, W, D) mm 160 x 36 x 50
the size is as above should fit within your hole size
aberdeenpaul is offline   Reply With Quote
Old 09-04-2009, 3:22 PM   #3 (permalink)
Thanks AP. I had seen that dimmer. Question is whether I can make hole big enough for it in ceiling which would be covered up by standard light fitting. Want to avoid having to replaster after dimmer has been installed.
Old 09-04-2009, 8:35 PM   #4 (permalink)
Thanks: Gave 1, Got 13
You should be able to fit a Rako through the ceiling rose. If it wont go and you are worried about making the whole bigger you could always remove the board from the casing and fit that through.
DaveChester is offline   Reply With Quote
Old 09-04-2009, 9:07 PM   #5 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,332
Having exposed live connections in the ceiling is both dangerous and potentially lethal. The Pill Dimmer needs a minimum load to operate how many bulbs are you controlling?
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
Old 09-04-2009, 9:51 PM   #6 (permalink)
It would be for approximately 6 bulbs. Do not want to use pill as this works only with very limited range of bulbs (and no energy efficient bulbs). Was hoping to be able to fit ceiling dimmer (e.g. RDL250C) through hole above ceiling rose.
Old 11-04-2009, 6:33 PM   #7 (permalink)
Assured Advertiser
The RDL are designed to fir through a downlight sized cutout, It should fit but you may need to adjust the fitting of the rose if there is hole for an RDL cut out.
choice, dimmers, lighting, rako, system
