Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
LG 32LC2D - Settings Thread NinjaBaz LG Owners' Forum 582 13-07-2009 6:57 AM
Wanted : 37" Panasonic Plasma Set (Flexible on location) -DT- TV and Projector Classified Adverts 9 02-04-2009 9:25 AM
KDL32D3000 switching off and on by itself animalmagic Sony Owners' Forum 12 29-03-2009 11:44 AM
Sony STRDA2400ES & setting up Kef 2005.3 StevieDvd Sony Owners' Forum 1 26-03-2009 6:22 PM
Advice on amp for set up drew_bwfc AV Amplifiers and Receivers 2 26-03-2009 6:04 PM
Old 26-03-2009, 7:00 PM   #1 (permalink)
Thanks: Gave 5, Got 1
Help with dimmer switch set up!
I have decided to do something about the lights in my living/Dining room.
I have one dimmer that controls both of them, (so when one comes on the other does as well) I want to split them so I can turn them on seperately.
I have looked and the dimmer switch I have is rated at 250w. Does that mean I should get a split dimmer switch rated at the same?
Thanks guys
Sonofabeesting is offline   Reply With Quote
Old 26-03-2009, 7:32 PM   #2 (permalink)
Re: Help with dimmer switch set up!
To run them seperatly you will another switch wire - unless there is two in there?
What type of light fittings are they and whats the wattage of the bulbs.
Chris
Toleman is offline   Reply With Quote
Old 26-03-2009, 8:10 PM   #3 (permalink)
There is two in there already, one to each light fitting.
In one fitting is an energy saving light bulb (yes I know you shouldnt have this but it was put in by the previous tenants) so that will be swapped and in the other is a regular bulb which is rated at 60W.
I was also thinking that I would change these for lower rated ones to save some energy.
Old 26-03-2009, 9:15 PM   #4 (permalink)
Ok, as long as the two cables in there are switch wires. If the neutrals are conected one is the supply and one is the switch.
Im not up to scratch with the ratings of dimmers but as long as you cover you 120w (2 x 60w) then you will be fine.
Chris
dimmer, set, switch
