Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Ninja Blade - Rather good !!!! Mr-Bananas Xbox 360 Game Previews 38 03-05-2009 11:11 AM
are bose any good ? Phill1978 Speakers 29 24-03-2009 9:00 PM
Assassination of Jesse James (UK) - good upgrade? kwebbotaurus Blu-ray Movies and TV Programmes 5 24-03-2009 8:22 PM
Good Alternative Wall Mount and Table Stand for Pioneer KRP 600M? CKO Flat Screen TV Brackets and Mounts 9 24-03-2009 2:43 PM
Old 24-03-2009, 12:34 PM   #1 (permalink)
Thanks: Gave 23, Got 12
Looking for a good switched mains socket.
Does anyone know of a good switched mains socket / strip. I am looking at something that will switch a mains socket when my Onkyo 805 Receiver turns on / goes into standby. I have looked at the Intelliplug / Intellipanel range but they seem to also switch off the Reciever after a short while. I would like to use the Onkyo Switched 240v AC outlet but that does not have enough power but something that could be switched by that output would be ideal.
JohnWB is offline   Reply With Quote
Old 24-03-2009, 2:28 PM   #2 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,332
Re: Looking for a good switched mains socket.
Then you would want a Double pole relay controlled by 240V AC Maplins aell them but you will need to build a safe enclosure. (often easier to use the 12V out as that will happily run a relay and save the 240V out.
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
Old 24-03-2009, 3:49 PM   #3 (permalink)
Thanks for the info, I had considered that but when I checked the manual, the 12v out is only for zone 2. It may be the 240v system then if I cannot find anything else.
good, kooking, mains, socket, switched
