Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 01-03-2009, 11:03 AM   #1 (permalink)
Azzin's Avatar
Thanks: Gave 1,995, Got 446
Talking n00b alert!
Hi all,
I've got a basic remote control plug kit that I bought (of all places!) from Notcutts Garden Centre for £15!
It works fine and I can turn our three sidelights on & off using the small 4 button receiver.
The thing that puzzles me is why it has 4 on/off buttons, when it's a three pack for 3 devices....
It has 4 on and 4 off buttons, but what on earth is that 4th button for?
Anyway, I've just ordered a Harmony One to replace our recently deceased 885 and I'm wondering if I can program that to control the lights?
Thanks.
[Edit] - Actually, I'm not sure if the Notcutts unit is even Infra Red, so if that's the case what are my options?
Optoma HD70 with 95" Screen|Sky HD|Onkyo TX-SR606|Jamo A102s|120 gig XBOX 360|USA 500 gig PS3|Wii|Harmony One
Azzin is offline   Reply With Quote
Old 01-03-2009, 11:27 AM   #2 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,332
Re: n00b alert!
its not its a 433Mhz RF remote same as used with garage door openers harmony wont control these devices and scodes are normally proprietry so you will have to use original remote why a 4 button remote it may just be thats the standard button layout
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
Azzin (01-03-2009)
Old 01-03-2009, 11:29 AM   #3 (permalink)
Azzin's Avatar
Question Re: n00b alert!
Thanks, are there any cheap IR kits that I can buy to operate the lights using a Harmony One?
Old 01-03-2009, 4:58 PM   #4 (permalink)
Assured Advertiser
Re: n00b alert!
Varilight IR dimmer switches are the cheapest
Azzin (01-03-2009)
alert, n00b
