Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Title Update on COD WAW Stream62 Call Of Duty (COD) Xbox 360 16 17-07-2009 10:43 AM
Anthony Gallo ADiva Ti vs Micro Ti Grayman Speakers 16 09-03-2009 9:29 AM
For Sale : Black Nintendo DS Lite and Acekard with 2GB Micro SD Teesside_Craig Gaming Classified Adverts 1 03-03-2009 12:13 PM
Old 28-02-2009, 8:48 AM   #1 (permalink)
Thanks: Gave 47, Got 10
LW12 Micro Module
Hi all,
Really simple question.
I'm planning on using the LW12 in wall module for a 2way lighting setup, but have also been looking at my normal single way lighting for the rest of the house.
If i want to stay with in wall stuff, is the LW12 my only option/best option?
If i want them on remote control then i assume i need a transmitter like the TM12/13 ?
bjarvis2785 is offline   Reply With Quote
Old 28-02-2009, 10:20 AM   #2 (permalink)
Thanks: Gave 4, Got 118
Re: LW12 Micro Module
LW12 is a good option if you consider the following....
1) they should only be used with dimmable lamps.
2) you need a suitable controller to program them up.
A TM13 and suitable remote will give you wireless remote control of the lights.
320GB PS3, TH42PY800, Marantz SR5500, MA GR10 fronts, MySky HDi, Harmony 885, MJ Pro50ii Sub
PSN: Gadgetcity
Gadgetcity is offline   Reply With Quote
bjarvis2785 (28-02-2009)
Old 28-02-2009, 7:18 PM   #3 (permalink)
thanks,
From my understanding i only need to program them for remote control (and possibly dimming?) - but i wouldn't need to program them for just on/off - is that right?
The reason i ask is that i won't be integrating them into any kind of home system yet, but would like to install them for future use.
Old 28-02-2009, 10:51 PM   #4 (permalink)
Letsautomate.com has a useful diagram and datasheet for the LW12. Remember that you need momentary mains switches in your new setup. The lights will turn on and off and dim from the switch. You are right, you should only need to program them up when you start using x10 remote control.
PSN: Gadgetcity
lw12, micro, module
