Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
As I said the ref at the Wales match was iffy la gran siete Sport 26 02-03-2009 4:51 PM
What do I have to do to NOT get given an AMSTRAD SKY HD BOX Baldybouncer Sky HD 36 28-02-2009 4:19 PM
Connecting an xbox 360 elite to a monitor via HDMI to DVI-D cable. stg23 Xbox 360 Hardware 6 27-02-2009 9:02 AM
How to get a better ping k4p84 Sky Broadband 12 25-02-2009 9:59 AM
Old 25-02-2009, 1:27 AM   #1 (permalink)
Arrow X10 alarm system - record cameras to the internet?
Has anyone had any luck setting up their X10 alarm system to record video footage to the Internet when an alarm is tripped? There are a number of security systems out there which can dial out, but I'm looking to tie them in with a piece of software that will upload any footage (probably as still shots) to a remote FTP location.
Any suggestions?
Signature deleted by Admin
homeautonutter is offline   Reply With Quote
Old 25-02-2009, 5:47 AM   #2 (permalink)
Thanks: Gave 4, Got 118
Re: X10 alarm system - record cameras to the internet?
You can configure Supervisioncam to record based on the input to a game port if your PC has one. You can control this from an x10 relay module. Supervisioncam can then upload the pictures to an FTP site. I just use the motion detection myself so the x10 stuff is seperate.
It would be a bit ad-hoc and messy but it is possible.
320GB PS3, TH42PY800, Marantz SR5500, MA GR10 fronts, MySky HDi, Harmony 885, MJ Pro50ii Sub
PSN: Gadgetcity
Gadgetcity is offline   Reply With Quote
Old 27-02-2009, 6:23 PM   #3 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,332
most network DVRS have an alarm input (basic relay) that could take a feed from X10 system
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
Old 06-03-2009, 9:08 PM   #4 (permalink)
Some IP CCTV cameras have motion detectors built in to do this. Have a look at the Panasonics.
LHanna is offline   Reply With Quote
Old 08-03-2009, 1:05 PM   #5 (permalink)
Might not be any use to you, but I use normal webcams (Philips Toucams) hooked up to the linux server that does all my HA stuff, with a piece of opensource software called "motion" that can do loads of things, including emailing or ftp-ing the stills or video.
Check this link WebHome < Motion < TWiki
dmb0058 is offline   Reply With Quote
Old 15-03-2009, 9:13 AM   #6 (permalink)
Thanks: Gave 1, Got 16
Any suggestions?
I use Zoneminder on a Linux server to do motion detection on my CCTV system. It has the facility to interface with X10 I believe, although I'm not sure if that is to trigger an X10 device when motion is detected, or vice versa. As it detects motion automatically though, it could be independent of the alarm system and still record video.
Ben
benwillcox is offline   Reply With Quote
alarm, cameras, internet, record, system, x10
