Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
My Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray Review
Scrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
For Sale : Panasonic NN-CS596S Steam Plus Microwave tigermad Electrical Goods Classified Adverts 20 20-04-2009 6:05 PM
Ideal 606 setup for PS3, 360 and Sky+ HD RagingKileak Onkyo Owners' Forum 4 26-02-2009 10:28 AM
Old 24-02-2009, 9:48 PM   #1 (permalink)
Thanks: Gave 47, Got 10
Two-way remote light switch for downlights
Hi all,
I'm soon to be re-decorating the hall, stairs and landing and as part of this will be installing downlights in the ceilings.
I thought i would also take this chance to get some home automation started and was thinking about implementing X10.
My questions is what would i need as i have a two way lighting circuit at the moment - both hall and landing can be switching from both top and bottom of stairs.
i'm a complete noob to X10 so don't really understand all the module at the moment, so what would i need and is it even possible?
I would also like the switches to be remote (is this standard in X10?) but also need them to be physical switches/buttons, so i can use the wall switch AND the remote.
I'll be getting somebody in to install them, so as long as i can get the right stuff we'll be sorted
bjarvis2785 is offline   Reply With Quote
Old 24-02-2009, 9:50 PM   #2 (permalink)
Thanks: Gave 1, Got 18
Re: Two-way remote light switch for downlights
What is your budget?
I personally find the X10 stuff not very aesthetically pleasing, and would rather go with a completely hidden system, such as Rako.
I'm happy to help you spec certain systems if you give a few more details. Room dimensions including ceiling heights would also help.
silver12 is offline   Reply With Quote
Old 24-02-2009, 10:00 PM   #3 (permalink)
Thanks for the quick reply.
At the moment, this is only for the hall and landing ceiling, each would have 4x downlights - haven't bought these yet so haven't settled on wattage etc.
Budget - well, as i'm a complete noob to this sort of stuff i don't really know how much i should be looking at.
It's more of a feasibility thing at the moment, if i can find out the equipment that i would need and then see if it's too much etc
I ibviously don't want to spend loads as at the end of the day, it is only the hallway and landing, but it would bea nice touch
All i need to do is has a 1-gang switch upstairs and 2 gang downstairs that can also be controlled via remote control.
If this isn't suitable for X10 then obviously i am open to suggestions.
EDIT: Sorry, forgot to say, rewiring is a no-gp i'm afraid, so something that can utilise existing wiring is a must...
Old 25-02-2009, 12:47 AM   #4 (permalink)
Smile Re: Two-way remote light switch for downlights
In regards to the aesthetics, you could always depend on the likes of micro-modules. You could use an in-wall, X10 dimmable light receiver (not rewiring, but not sure if it's still an option to you bjarvis2785) and couple that with X10 switches or a touch screen and you may have the sort of system you're after. It can be relatively inexpensive too, particularly for such a small area.
homeautonutter is offline   Reply With Quote
bjarvis2785 (25-02-2009)
Old 25-02-2009, 9:44 AM   #5 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,332
Varilight will do IR contorl of basic circuits with switch replacement units, Lutron Rania IR do the same for 3-4 times the price
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
Old 25-02-2009, 11:35 AM   #6 (permalink)
Thanks for the info.
Would that LW12 handle a 2 gang switch though, or would i need 2 of them (one for each switch) - also, how would it handle a 2 way circuit?
It sounds like what i want (being able to respond to remote actions and manual momentary switches)
Also, i assume this would not work on a transformer based low voltage system, and that i would need mains voltage downlights?
sorry for all the questions
Old 25-02-2009, 3:28 PM   #7 (permalink)
Just read up some more on that LW12 module... it looks like it's what i'm after so have sent the manual off to the install guy (my dad, lol ) to have a look at
Thanks for the help on this one guys!
Just gotta go and find some switches that i like... this might be a daft question, but will any momentary switches work with this LW12 or would i have to look for X10 specified switches?
downlights, light, remote, switch, twoway
