Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
Is there a wireless AV receiver? dundeeedd Home Automation, Lighting, Security, Heating and Cooling 6 25-02-2009 1:07 AM
Old 23-02-2009, 9:20 AM   #1 (permalink)
Hey guys, not going to bore you all with the usual "I'm new to all this blaa blaa". I will keep it short and sweet.
Is there such a thing as a wireless AV receiver?
The reason I ask is that I am in the planning stage of my project and I am looking at ways of controlling my SKY HD box from another room (if the box is stored under the stairs with the rest of my home network equipment).
Would liek to know if anyone ahs any suggestions before I start tracking my walls.
dundeeedd is offline   Reply With Quote
Old 23-02-2009, 10:47 AM   #2 (permalink)
Thanks: Gave 13, Got 3
Re: Is there such a peice of equipment
hi, and welcome!
You could easily do this. all you need is an IR repeater this will allow you to control via a remote and the IR repeater will control the sky HD box (and any other equipment) inside the cupboard
as far as "wireless av receivers" you can get wireless HDMI but its not cheap Belkin are releasing one named firefly
Ian
_______________________________
Planning - HD65 with 89" Screen, Onkyo 576, 32LG5700, HTPC running windows 7 - Bluray, HD-Drive, Freesat with BBCHD, SKY HD, Home Server with 5TB of storage!!
ian_solway is offline   Reply With Quote
Old 23-02-2009, 11:02 AM   #3 (permalink)
Hi Ian
Thanks for this, yeah found it hard to find HDMA wireless equpment, all the AV receivers are old generation it seems. I think however no matter how expensive it is I will have to bite the bullit and pay for it as I don't fancy tracking all my walls.
I will look into this firefly
Again thanks for the input
Edd
Old 23-02-2009, 1:13 PM   #4 (permalink)
Thanks: Gave 9, Got 21
If you don't need HD sent around the house there are other lower res and way cheaper A/V senders around, Google 'digisender'.
You could also send A/V around on Cat5 cables if you have any installed, if not, this is a lot easier than running A/V cables.
Google 'video balun'.
nacmacfeegle is offline   Reply With Quote
Old 23-02-2009, 1:14 PM   #5 (permalink)
inzaman's Avatar
Thanks: Gave 91, Got 365
Re: Is there a wireless AV receiver?
Moved to Home Automation
Visit my Home Cinema here
inzaman is offline   Reply With Quote
Old 23-02-2009, 3:36 PM   #6 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,332
What are you trying to "receive" ???? IS it just control you want? or Picture and sound as well?
At what quality and what budget?
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
Old 25-02-2009, 1:07 AM   #7 (permalink)
Shouldn't be too hard to find one; in Australia they're pretty TV transmitters for PayTV such as Foxtel are pretty common, and include the I/R transmitters/senders as standard. Here they run on 2.4Ghz and 5.8Ghz bands, so I'm pretty sure it should be the same in Ireland and Great Britain.
Signature deleted by Admin
homeautonutter is offline   Reply With Quote
equipment, peice
