Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
alarm system akhlaq768 Home Automation, Lighting, Security, Heating and Cooling 12 25-02-2009 1:15 AM
Alarm systems and X10 control candg Home Automation, Lighting, Security, Heating and Cooling 12 11-02-2009 2:59 PM
Title deleted dnlmahon Subwoofers and Tactile Transducers 0 10-02-2009 10:07 PM
M3100 - MP3 as alarm, is this possible? eucalyptus9000 Mobile Phones and PDAs 0 08-02-2009 2:06 PM
Old 11-02-2009, 1:10 PM   #1 (permalink)
Thanks: Gave 13, Got 2
Alarm minefield
I have just moved into a new house with an alarm system fitted. Is it possible to add on to this system i.e dialler and cctv?
I'm a complete novice and any help would be appreciated.
I live in Manchester so if any one knows of anyone decent they can recommend?
Superman1175 is offline   Reply With Quote
Old 11-02-2009, 1:24 PM   #2 (permalink)
Thanks: Gave 36, Got 39
Re: Alarm minefield
I too live in Manchester and use HBA alarms. Just a guy on his own, but he's excellent. I know nothing else though!
H B A Alarms
33, Beaumont Rd, Manchester, Lancashire M21 8BG
Tel: 0161 881 7324
SirTiger007 is offline   Reply With Quote
Old 12-02-2009, 8:06 PM   #3 (permalink)
D4RK1's Avatar
Thanks: Gave 22, Got 17
Re: Alarm minefield
You can put a dialer onto any alarm panel in the world.
Most domestic panels have 8 zones, check to see how many leds you have on the keypad, this will let you know how may zones you have available.
D4RK1 is offline   Reply With Quote
Superman1175 (16-02-2009)
Old 12-02-2009, 10:47 PM   #4 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,332
Re: Alarm minefield
CCTV wont normally integrate direct ot an alarm panel (can be made to work) but better to get some pro advice.
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
alarm, minefield
