Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Wanted : cheap but reasonable digital camera semiskimmed Digital Camera and Camcorder Classifieds 14 10-02-2009 9:11 PM
What's a SHY bloke to do??? Ned Senior General Chat 69 10-02-2009 12:13 PM
Samsung A756 firmware on A656 (to get Wiselink Pro) reddwarf2002 LCD Televisions 4 09-02-2009 8:17 PM
Old 09-02-2009, 8:26 PM   #1 (permalink)
Thanks: Gave 2, Got 0
Advise Wanted - I want to add remote control to my electric screen and lights
I have an electric screen currently operated by a rocker switch on the wall, that you press & hold to raise or lower the screen. I also have a double wall dimmer working the ceiling lights.
I would like to convert the screen control to remote and the lights aswell, can you please suggest what equipment I need.
Ideally I want to press a button and the screen comes down and the lights dim, press another and the screen rolls up and the lights fade back up. I also need to be able to move the screen up and down without altering the lights (for variable masking of the screen)
The only possible problem I can think of is the dimmer for the lights is around the other side of the knock though wall from where I normally sit (it has to be there as that's where the door is )
I know this is off topic but any suggestions as to one programmable remote to operate the above as well as my projector, av amp, dvd player
thanks
Wookie
wookieman is offline   Reply With Quote
Old 10-02-2009, 4:20 PM   #2 (permalink)
Thanks: Gave 0, Got 5
Re: Advise Wanted - I want to add remote control to my electric screen and lights
you would need a scenesetting system that has an inbuilt relay to send the signal to the motor to trigger the screen to raise and lower, and a dimming solution for the lighting. i'm not sure if a graffik eye has a relay option as a channel output?!
habrown is offline   Reply With Quote
Old 11-02-2009, 9:23 PM   #3 (permalink)
Been looking at Rako gear, i think the following will do what I want, opinions welcome....
1 of RACUB
- twin relay to operate the screen
£140
2 of RDL250C
- in ceiling dimmer unit
£79
1 of RCP07-W
- 7 button keypad for lights
£98
1 of RPS03-W
- 3 button keypad for screen
£129
RAVIR
- ir to rf convertor
£135
Grand Total = £660 + vat
I could loose the wall keypad for the screen and rely on the remote only but I do need the keypad for the lights, but that only drops the price to £531 + vat which is still bloody steep.
Help !!!!
Wookie
Old 15-02-2009, 5:42 PM   #4 (permalink)
Hmmm... I think that is one of the only ways this can be acheived. Rako is also good equipment, so you shouldn't have too many issues. could be worth seeing if any other lighting controls manufacturers have anything to offer, but what you have picked is a good set up.
add, advise, control, electric, lights, remote, screen, wanted
