Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
best mains power cord for my amp evans Hi Fi Systems and Separates 38 04-02-2009 8:10 AM
Sherwood RD7103R mains transformer jonnygeeart AV Amplifiers and Receivers 0 03-02-2009 11:59 AM
Mains Networking RF Interference graystreet Networking and NAS 2 30-01-2009 7:40 PM
Old 03-02-2009, 2:58 PM   #1 (permalink)
Thanks: Gave 0, Got 5
Mains Halogen
I have just taken down a normal light fitting and placed a mains halogen fitting in its place and also joined another mains halogen fitting further down the wall.
This is ok isn't it? Everything is working fine.
I have a dimmer at the top of the stairs and a normal switch at the bottom, and when i turned the dimmer down i got a buzzing noise as if electric is going through something i understand that dimmers can do this and i can hear it when i put my ear to the dimmer but when i turned the dimmer back up to full i could hear a buzzing noise still and i found it was 1 of the mains halogen fittings.
Do mains halogen fittings/bulbs buzz at all? They are brand new so do the GU10 bulbs buzz when new possibly? I have to admit I can't hear the loud buzzing anymore.
The dimmer switch was there when i moved in so it could be old and i don't know the rating of it ( i haven't checked) and i do have a new silver/touch/remote dimmer to put on.
1 thing i have noticed is that there is a ceiling light also and that has a energy saving lamp in it and before i changed the wall lights when i turned the dimmer down it would flicker which i understand energy saving lights can't be dimmed, but now i have these halogens on the wall when i dim the ceiling light doesn't flicker anymore. Could this lamp have something to do with the whole problem? Should i just but a normal bulb in this fitting?
chrish16 is offline   Reply With Quote
Old 03-02-2009, 3:17 PM   #2 (permalink)
Thanks: Gave 1, Got 493
Re: Mains Halogen
You definitely need to replace that low energy lamp with an incandescent one.
These are a good compromise (B&Q sell them)
Steve
stevelup is offline   Reply With Quote
Old 03-02-2009, 4:24 PM   #3 (permalink)
Re: Mains Halogen
I new i would need to change it thanks.
I'm actually putting a halogen fitting up on the ceiling so don't need a bulb thanks.
Can you get GU10 bulbs that are less than 50W or should i just use 50W a nd dim it a little?
Also i have a fitting for the ceiling with 6 GU10 bulbs at 50W and the two on the wall so thats 400W so do i need a 600W dimmer?
Also i have just checked and behind the dimmer is like 4 sets of cables, does this mean that one is from the mains lighting circuit, 1 from the ceiling light, 1 from the wall lights and 1 from the other switch in the 2 way circuit? Shouldn't all these wires be in a junction box?
To add dimmers all i need is a suitable 2 way dimmer and then note and transfer the live, switched live and common wires into the dimmer and then on the slave dimmer add the same 3 wires and then all should be fine?
Will the circuit take that mains bulbs btw - 400W? A lot i know and don't fancy the electric bill but hopefully i can get less than 50W bulbs or i will have them dimmed slightly, and most of the time will be dimmed very low for watching movies.
Old 03-02-2009, 4:44 PM   #4 (permalink)
Re: Mains Halogen
You can get 20 and 35W GU10 lamps as well.
With regard to dimmers, if you use conventional ones, you must have a switch at one side and a dimmer at the other. You cannot have both controls as dimmers.
If you wish to be able to dim from both locations, and you currently have 3 core cables running between the two switch points, then you can use these: iQ Remote / Touch Control. You need a master and slave unit. They have the added benefit of being remote controlled.
All I'd say though is that dimmers and mains voltage halogens are a bit of a recipe for pain. Often when the lamp blows, it can damage the dimmer...
Steve
Old 03-02-2009, 7:31 PM   #5 (permalink)
Re: Mains Halogen
Originally Posted by stevelup View Post
Steve
I've seen some Philips 35W bulbs which i may get. I've seen tonight in Morrisons their own make 20W but do you think they'll be good enough quality? I couldn't find any good makes of 20 and 35W bulbs online.
How would i know if the dimmer is damaged?
I only really want to put the dimmer on at the bottom of the stairs to give the soft start feature to help to save the lamps.
I have white back boxes which are wall mounted and i actually have silver coloured dimmer fronts, do you have a solution to change the colour of the back box?
Old 10-02-2009, 1:41 PM   #6 (permalink)
Re: Mains Halogen
I would reccomend Osram GU10's if you were to use GU10's at all, as they come fitted with a fuse in-built. They are a little more money, but one of the many problems with GU10's are that when they blow, they go short circuit and take out the fuse or MCB, and all your lights go out! then you have the challenge of finding out what bulb has blown before putting a new fuse in, or it will blow again...
habrown is offline   Reply With Quote
Old 11-02-2009, 8:55 AM   #7 (permalink)
Re: Mains Halogen
Where is the best place to buy the osram ones then?
I'd be looking at getting 20 or 35 W
Old 18-02-2009, 5:59 PM   #8 (permalink)
Thanks: Gave 1, Got 18
Re: Mains Halogen
You can also buy LED and compact fluorescent lamps in a GU10 format, but they don't like being dimmed.
You can buy push button dimmers that will work on a two way lighting circuit.
silver12 is offline   Reply With Quote
halogen, mains
