Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
Wanted : Carnivale Series 1 & 2 (Region 1 N.America) norliss Movie and Music Classified Adverts 9 10-04-2009 1:54 PM
For Sale : 5x B&W M1, Black, as New swift1 Speaker and Subwoofer Classified Adverts 40 05-02-2009 6:31 PM
Old 02-02-2009, 1:36 PM   #1 (permalink)
Front Door Camera & Screen
I would like to have a "designer looking" screen by my front door that shows who is outside my front door. I want it small enough so that I can set it into the wall. I am not looking to record anything, nor do I want sound. Just a picture projected from a discreet camera located outside my front door. Does anyone know of a possible solution? I looked at Opus and wondered if they did anything?
intrinsic777 is offline   Reply With Quote
Old 02-02-2009, 10:54 PM   #2 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,332
Re: Front Door Camera & Screen
You can integrate CCTV to the OPus 600 keypad Opus 600 (UK) but its not a cheap way of doing it (cool if you want Audio in the house tho) there are some panel intercom door access systems have a look at Videx and BPT BPT Entry Control - Video Entry Monitors (BPT are pricey)2 of the big names you can also do this with Netstreams Digilinx (UK) but costs even more I'm afraid there are some other options b ut they would require a more DIY approach
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
Old 03-02-2009, 4:55 PM   #3 (permalink)
Thanks for the info. I really like the OPUS idea and realise it's gonna be rather expensive. Although there is the arguement that I can evolve this system around my house when time allows! Would I be right in thinking though that I would have to purchase a media hub/server as well as the panel even though from the offset I just want to project an image onto the panel?
Old 03-02-2009, 6:35 PM   #4 (permalink)
Assured Advertiser
IF all you wanted was to see the camera image then i think you can get away without the hub you would need to speak to your local Opus dealer which may be Opus 600 (UK) ...
camera, door, front, screen
