Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
PC Freezing (URGENT help) dmx0007 Windows Vista 7 03-02-2009 11:05 PM
Panasonic TH-42PZ80 I need help convincing myself. Please help! vwgolfman Plasma Televisions 25 02-02-2009 10:31 PM
Remote programming and best of my ones to use? help pls huntaaar Remote Controls 6 02-02-2009 12:00 AM
Help! PS3 Won't play discs Robbo456 PS3 3 01-02-2009 6:14 PM
Aerial & Electric gate - problem HELP RobinDB Home Automation, Lighting, Security, Heating and Cooling 2 01-02-2009 5:27 PM
Old 01-02-2009, 6:14 PM   #1 (permalink)
Thanks: Gave 13, Got 21
Wall light wiring help
Hopefully someone can help, I have put up 2 wall lights but when I flick the switch nothing happens.
From the first point I have 2 cables each with a neutral and live wire and a bare wire which I assume is the live? 1 of these cables feeds the other wall light. From the 2 cables I have stripped and fed both live and neutral into the light and both the bare wires to where the live should be. I then hooked up the other light with the 1 cable poking out the wall.
When I switch the lights on nothing happens. Here's a picture of the wiring, am I doing it correctly??
willo is offline   Reply With Quote
Old 01-02-2009, 6:56 PM   #2 (permalink)
Thanks: Gave 22, Got 91
Re: Wall light wiring help
Bare wire the live?! No, no, no! The bare wire is the earth, and should be sleeved with green and yellow PVC sleeving. Are you sure youve turned the MCB back on? No offence intended, but with what youve written in your post, I would get a professional in!
AV:Samsung 19" (Kitchen) 32" (Bedroom) 40" (Lounge), Panasonic PT-AX200, SkyHD, Pioneer 868, Onkyo 605, MS902i/905/302, BK XLS200, Harmony 885 x2, Squeezebox Duet, HTPC Gaming:360 Elite PS3 Wii Modded Xbox Flashed PSP
My old bedroom setup My new home cinema and multiroom - DIY work in progress
MitsiTurbo is offline   Reply With Quote
Old 01-02-2009, 7:33 PM   #3 (permalink)
Thanks: Gave 6, Got 29
Hi, sounds like your not sure and it would be best to get a pro do your electrics if you are not sure. I have seen far too many dangerous installations and one other thing to consider is your home insurance if you cause a fire from wrongly connecting things up then they might use that as a reason not to pay out.
But if you wish to continue and assuming there is power in the circuit then from the picture you show this looks fine although I would recomend earth sleave (green/yellow) on the bare wires. So that would lead me to think there is either an issue with the way the switch is wired or most likely at the point where the wires teminate most likely in the ceiling which is where most people get confused and connect the switched live wire (normaly has a red sleave on it especialy if the blue wire has been used as a switched live) to the common live that runs around the lighting circuit. So first things first with the power off and using a test meter make sure you have connections between each of the points and use a length of spare wire to make a ciruit bell out each wire. If after that all is connected ok and it still doesn't work then call in help.
Packers-PT-AE2000 Projector,Motorised Screen,Sony Bravia 46" LCD,Denon 4308 AV AMP,Mission Speakers E83 x 2, E8C x 1, M70DS x 4, M&J Pro50 x 2,SKY HD,Xbox360,PS3,Wii,iPod,Harmony 1000 Remote
askpackers is offline   Reply With Quote
Old 02-02-2009, 7:56 AM   #4 (permalink)
Cheers guys, I got my wording wrong. I have 3 wires, brown, blue and bare. I have connected brown to brown and blue to blue, the earth (bare) wire I have attached to the light fitting.
Having spoken to a electrician friend it might be that the wires might not be connected to the switch which might make sense as there seems to be no power. I think I'll leave it to a pro, there was me thinking it would be a simple case of wiring it in.
light, wall, wiring
