Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
looking for remote curtains avcar Home Automation, Lighting, Security, Heating and Cooling 2 25-01-2005 11:37 PM
Remote Controlled & Electrically Operated Curtains JonSpokes Projectors 3 06-08-2001 10:00 AM
Old 15-09-2008, 1:06 PM   #1 (permalink)
Thanks: Gave 15, Got 6
Remote control curtains?
Hello
I am interested in installing some remote control curtains in my Bay window-total run approx 4.5 metres.
Does anyone actually have any installed they can kindly recommend?
I am not even sure if it is feasible as overcoming the bends for the bay with a motor each side may be difficult?
I currently have a plastic rail I installed several years ago but it has never run smoothly (probably due to my DIY!) and I thought of adding a RC motor I saw on Ebay-however I think I need a Professional to install such a thing
Any thoughts would be really welcome
Many thanks
yoghurt is offline   Reply With Quote
Old 15-09-2008, 8:25 PM   #2 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,332
Re: Remote control curtains?
Have a look at Silent Gliss the masters of automated curtains
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
Old 15-09-2008, 9:24 PM   #3 (permalink)
Thanks Horny Dragon
Yes the 5090 range can be fitted to bay windows-will check it out
CHeers
Old 16-09-2008, 2:33 PM   #4 (permalink)
vex
Assured Advertiser
Thanks: Gave 9, Got 181
I have always found Silent Gliss anything but Silent.
Personally prefer Golst's G-Rail system but neither are cheap at all. For that sort of run I would guess at between £500 and £800 depending on the weight they need to carry.
V.
Be careful out there forumites - 89% of statistics are made up.
vex is offline   Reply With Quote
Old 16-09-2008, 2:51 PM   #5 (permalink)
Hi Vex
I measured the run last night and its actually 3 metres (!)
As you say, its not cheap-the 5090TL range of silent gliss was about £460 (inc £95 for bending the rail).
Will take a look at Golst's G-Rail
The other (hopefully cheaper) option I thought of was to get a decent manual 'pulley' system installed professionally (so it runs smoothly) and then later on add a motor on each end of the bay I had seen for sale on Ebay (see http://www.avforums.com/forums/showt...rtain)-However I can see you were not convinced by them
many thanks
Old 01-12-2008, 1:28 AM   #6 (permalink)
Although you're right, 'Silent' Gliss aint silent, it's still not exactly noisy!!
The cheapest place I've found so far is at www.discountelectriccurtains.co.uk - I have'nt tried one of the cheaper makes yet, but it isnt something you buy everyday!
Laters,
Tony.
TonyFuller78 is offline   Reply With Quote
control, curtains, remote
