Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
replacing a faulty room thermostat carlymart Home Automation, Lighting, Security, Heating and Cooling 2 19-12-2007 9:05 PM
Room Thermostat Question stevegreen General Chat 16 01-08-2007 11:04 PM
Room thermostat ian1888ah General Chat 3 27-01-2007 4:40 PM
Digital Room Thermostat Johndm Home Automation, Lighting, Security, Heating and Cooling 16 10-11-2006 12:41 PM
Another room thermostat question KillerOfThreads General Chat 4 27-09-2005 7:22 PM
Old 06-09-2008, 11:03 AM   #1 (permalink)
dmx005's Avatar
Thanks: Gave 56, Got 19
Hi all,
would be grateful for some advice. Our room thermostat is faulty and I have replaced it with a new one. There are 3 wires, red, yellow & blue although the blue is cut short and wasnt connected to anything in the old thermostat.
There are 3 terminals on the thermostat and Ive connected the yellow to 'on', the red to whats only numbered as '2' and no cable in the terminal marked 'off'.
When I put the power back on after connecting, the boiler starts but the thermostat doesnt switch it off.. Ive tried other combinations with the cables but it seems to be either always on or not at all.
Should I be using the blue (neutral I guess) in the terminal marked 'off'?
any advice much appreciated.
::dmx::
dmx005 is offline   Reply With Quote
Old 06-09-2008, 11:10 AM   #2 (permalink)
Thanks: Gave 2, Got 19
Re: replacing a faulty room thermostat
No.
The nuetral is there for a pre heating resistor that some themostats use to even out large swings in temp.
I never apologise. I'm sorry but it's just the way I am
hufartd is offline   Reply With Quote
Old 06-09-2008, 11:12 AM   #3 (permalink)
dmx005's Avatar
Originally Posted by hufartd View Post
No.
thanks.. so any ideas why the boiler is always on regardless on whether the thermostat dial is switched on of off..? There are not many combinations - Ive only got 2 cables and 3 terminals to play with!
diagram & my wiring attached..
::dmx::
Old 06-09-2008, 2:15 PM   #4 (permalink)
Thanks: Gave 26, Got 109
The wiring diagram shows that terminal 1 should be your live feed from the boiler/boiler control circuit and that terminal 2 is the switched live back to whatever is to be controlled. Depending on your current wiring arrangments the stat will be wired in series with your central heating timeclock/programmer and then feeds back to the boiler directly (if it's a combi) or to a 2-port or 3-port zone valve (standard S-plan or Y-plan arrangement common in most houses). In the s-plan/y-plan arrangements the boiler is activated by a switch in the valve actuator so there could be 2 problems if the heating is not switching off - the new stat could be faulty or the end switch of the actuator has failed and is constantly supplying a feed to the boiler regardless of whether the valve is open or not.
neilball is online now   Reply With Quote
Old 08-09-2008, 9:42 PM   #5 (permalink)
If you turn the dial to the lowest temp and slowly increase it do you hear / feel a click ? the switch breaking ? could be that the stat isn't switching properly ? do you have a meter ?? so you can test the switching of the stat ?
Charlie2 is offline   Reply With Quote
Old 09-09-2008, 10:42 AM   #6 (permalink)
Thanks: Gave 1, Got 9
The thing to remember is that the thermostat is simply a switch. To find out where the fault lies try this:
Remember to turn off the power before making or breaking connections - potential 240V on these wires
Disconnect the thermostat and leave the 2 wires apart. Turn on the heating (making sure that the hot water is turned off). Note what happens.
Turn the power off - connect the 2 wires together (using abit of choc block or similiar) and turn it back on. Note what happens.
If the same thing happened in both states then the fault is not with the thermostat
If it did turn off and then on in both cases then you now know whether the boiler expects a normally open (NO) or a normally closed (NC) connection. Work out which connection is which on the thermostat and Bob's your auntie
Make any sense ??
KW1816 is offline   Reply With Quote
faulty, replacing, room, thermostat
