Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
SKY+ modified for hard wired rear remote socket? stevebez Sky and Sky+ 6 27-09-2009 1:45 PM
Remote 13amp Socket & Harmony 1000? MickEP Remote Controls 16 12-07-2008 2:00 PM
Power usage in standby and using a remote controlled socket COUGHCOUGH Plasma Televisions 7 20-09-2007 12:56 PM
Wired remote extender socket on sony amp? AndyCob Home Automation, Lighting, Security, Heating and Cooling 6 05-09-2007 8:35 PM
Old 03-09-2008, 7:50 PM   #1 (permalink)
scsracing's Avatar
Thanks: Gave 8, Got 16
Remote socket,75,000amps
Right i am after a remote socket that plugs into the wall that can be turned off by remote,It needs to be rated for 75,000 amps though i am finding it hard to find one,anyone know of one or a place i can get them.
Scott
scsracing is offline   Reply With Quote
Old 03-09-2008, 8:50 PM   #2 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,332
Re: Remote socket,75,000amps
75,000 AMPS? You want to remote control a power station? or a whole town?
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
Old 04-09-2008, 3:28 PM   #3 (permalink)
scsracing's Avatar
Well i am only new to this but i have a extension lead surge protector jobbie and it is rated up to 75,000 amps so i thought that must be the rating the remote socket needs.I would like to plug the extension lead into the remote socket as its in a hard to reach place.I run a few things off it
Toshiba 32xv505db
Xbox 360
Turtle beach
Laptop
Ikea light
What amp rating would i need then as i have know idea.
Scott
Old 04-09-2008, 5:24 PM   #4 (permalink)
Thanks: Gave 22, Got 91
The 75,000 amps is something different. Thats the level of protection it will give to your equipment if say a bolt of lightning were to get into the cabling. You will need to look for 13A which is the maximum on a domestic socket.
AV:Samsung 19" (Kitchen) 32" (Bedroom) 40" (Lounge), Panasonic PT-AX200, SkyHD, Pioneer 868, Onkyo 605, MS902i/905/302, BK XLS200, Harmony 885 x2, Squeezebox Duet, HTPC Gaming:360 Elite PS3 Wii Modded Xbox Flashed PSP
My old bedroom setup My new home cinema and multiroom - DIY work in progress
MitsiTurbo is offline   Reply With Quote
Old 04-09-2008, 6:34 PM   #5 (permalink)
scsracing's Avatar
Ok i see know,thanks for the help,like i said i am new to these sort of things so i am slowly learning just need to be taught.
Scott
Old 04-09-2008, 9:30 PM   #6 (permalink)
Everyone has to start somewhere mate. Ive taught myself most things as ive gone along. Its all about having the confidence to jump in and do things.
Im afraid I had to laugh at HD's post above though... classic!
Last edited by MitsiTurbo; 04-09-2008 at 9:31 PM. Reason: EDIT: That was supposed to be sn igger (without the space!)
000amps, remote, socket
