Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Lighting - TV/Stereo/Wall/Shelf Ambiant Lighting for your setup! Noodleman Home Automation and Lighting Power Buys 618 29-06-2009 9:56 AM
behind television lighting (well room lighting in general) c3lica Home Cinema DIY 3 21-06-2008 4:37 PM
Which lighting control system & blub type for living area lighting flying low Home Automation, Lighting, Security, Heating and Cooling 8 28-10-2007 7:40 PM
Recommend whole-house controller... jeffw_00 Home Automation, Lighting, Security, Heating and Cooling 0 01-01-2007 8:12 PM
Old 03-09-2008, 11:13 AM   #1 (permalink)
Thanks: Gave 22, Got 91
Recommend me a lighting controller...
Guys,
The final lighting setup is in place now and as such I need to get myself a lighting controller.
Needs to have 4 zones, and as many programmable scenes as possible.
Mode Scenestyle 4 seems quite good but ideally would like more than 4 scenes.
Any other offerings?
The lighting is as follows, 2 zones of rope lighting, 1 zone of 6x 35W GU10, 1 zone of 3x 50W GU10. No low voltage lighting included.
Many thanks
John
AV:Samsung 19" (Kitchen) 32" (Bedroom) 40" (Lounge), Panasonic PT-AX200, SkyHD, Pioneer 868, Onkyo 605, MS902i/905/302, BK XLS200, Harmony 885 x2, Squeezebox Duet, HTPC Gaming:360 Elite PS3 Wii Modded Xbox Flashed PSP
My old bedroom setup My new home cinema and multiroom - DIY work in progress
MitsiTurbo is offline   Reply With Quote
Old 03-09-2008, 12:14 PM   #2 (permalink)
Thanks: Gave 0, Got 13
Re: Recommend me a lighting controller...
How much do you want to spend?
Lutron Grafik Eye has 8 scenes
Bruce_ is offline   Reply With Quote
Old 03-09-2008, 1:02 PM   #3 (permalink)
Bruce,
My mum and dad have a 4 zone Grafik Eye and I do like it. However, its a bit more than id probably be wanting to spend. Theirs only has 4 scenes though, however it is about 4 years old. Is 8 scenes a feature of new models?
The Scenestyle is quite a good price but as mentioned I would like more scenes.
Would something like Rako do the job?
Forget to add before, it MUST have IR control aswell. Gotta have it programmed into Harmony activities
Old 03-09-2008, 6:31 PM   #4 (permalink)
Rako can do more than 8 scenes, and does IR. Different style of controller though. Probably about the same price as the GE.
Old 03-09-2008, 6:40 PM   #5 (permalink)
owain_thomas's Avatar
Thanks: Gave 56, Got 54
I might be missing something obvious but how does the Rako do more than eight scenes? for that matter, can it do more than four with the standard controllers?
flickr
HC - Rotel RSP-1068 Processor, Mac Mini running Plex, Arcam A90, Totem Arro Speakers
TV - Panasonic TH42PHD8 with Lumagen HDP
owain_thomas is online now   Reply With Quote
Old 03-09-2008, 10:03 PM   #6 (permalink)
Dunno what I was thinking. You're right of course. Rako can only do 4 scenes.
Grafik Eye needs a separate panel to access 8 scenes, I think. But I'm not expert with Lutron product.
Actually there doesn't seem much available for 8 scenes, in the cheaper end of the market. They all seem to do 4 scenes.
The ZEN dimmer does 8 scenes (DO NOT BUY IT)
Most of the commercial systems will do 8 scenes, but you are probably looking at more than £1000 (product + commissioning)
iLight has an 8 scene control panel. connected to a 4 channel dimmer, it's still £500 though.
Old 04-09-2008, 9:31 PM   #7 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,332
RS232 or IR can do more scenes IIRC as can clever use if special panels but the norm is 4 scenes. only having 4 circuits 4 scenes is nirmmaly enough 6+ circuits and it can be a struggle in open plan areas
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
Old 05-09-2008, 8:00 AM   #8 (permalink)
Ok, thanks for the input guys. I think im going to go for the Scenestyle 4 as I have just discovered that it has a holiday mode where you can program it to simulate occupancy. As I regularly go overseas for a couple of weeks at a time, its ideal!
controller, lighting, recommend
