Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
Harmony 785 with Varilight dimmers daveb975 Remote Controls 0 28-05-2008 5:37 PM
Harmony 525 and Varilight Remote Dimmers scubanorthy Remote Controls 3 30-04-2008 8:23 AM
Is Varilight ok for dimming to a certain % ? ipace Home Automation, Lighting, Security, Heating and Cooling 9 05-03-2007 11:50 PM
Varilight remote/touch dimmers Paulie-W Home Cinema Hardware Bargains and Discount Codes 12 02-02-2007 4:16 PM
Varilight dimmers getting warm? kevlar Home Automation, Lighting, Security, Heating and Cooling 3 03-10-2006 11:13 AM
Old 01-09-2008, 11:59 AM   #1 (permalink)
Thanks: Gave 2, Got 4
Varilight Dimmers not dimming from remote.
I've installed a couple of varilight dimmers in my living room. I've programmed them to operate from one of my existing remote controls, and the on/off from the remote works fine from anywhere in the room. But the dimming function only works when the remote is within a couple of feet of the sensor, any futher away and holding the button down doesn't do anything. I've tried it with several different remotes and they all do the same thing.
Also, is there any way of bringing the light on at full brightness even though it was dimmed previously? It's a pain having to hold the button down and quickly release at full brightness - usually I miss the peak and have to have a second go!
Love the fade-to-on. Just a shame they don't do fade-to-off as well. If they did both I wouldn't care about the remote dimming because fade on/off is all I want them for.
Hooloovoo is offline   Reply With Quote
Old 01-09-2008, 6:01 PM   #2 (permalink)
Thanks: Gave 7, Got 82
Re: Varilight Dimmers not dimming from remote.
I've just replaced one of mine, it suddenly stopped working alltogether. Its the 2nd one that has failed on me too, I like them but am starting to think it might be worth spending a bit more money.
To answer your other question, no, I don't think there is any way to turn on at full brightness when previously dimmed.
I'm guessing your dimmer is faulty. I get mine from TLC-Direct and they replaced my first failure no problem at all as it was less than a year old.
kevlar is offline   Reply With Quote
Old 02-09-2008, 8:24 AM   #3 (permalink)
I would be surprised if they are broken.
I have one single gang, and one two-gang, so that's three individual dimmer units all behaving in exactly the same way. I suppose they could all be from the same faulty batch, but I think that's unlikely.
I mean all the remote functions work if you're standing next to the switch, but from any more than metre away holding the button down on the remote doesn't do anything. If the lights are on and I press and hold the button, nothing happens until I release the button at which points the lights switch off.
I don't know if spending more money is the answer. I spent ages looking around at all the retro-fit remote dimmers and none of them work as I would like. It seems as usual the people who design the hardware never actually use it! I just ended up settling on the Varilights as being the cheapest way of (almost) doing what I wanted.
Old 02-09-2008, 11:22 AM   #4 (permalink)
Thanks: Gave 0, Got 13
Do you have a plasma or large screen LCD TV in the same room? If so, unplug it and test the dimmer again.
Plasma/LCD TVs are well known causes of interference. The effect is it reduces the range of the remote.
Bruce_ is offline   Reply With Quote
Old 02-09-2008, 11:42 AM   #5 (permalink)
Thanks: Gave 24, Got 22
They are definitely not broken as I have exactly the same problem. I have 3 dimmers (+ 3 slaves) controlling 3 sets of downlights and all dimmers turn on/off perfectly, however, holding down the assigned buttons on the remote (Philips Pronto Neo) to dim them doesn't work for any of them. I need to do a few more experiments with the Neo to see if there's a problem with the buttons assigned to the dimmers (I think the assigned buttons may be set to an on/off function rather than a "continuous hold" function). I'll let you know the results.
It's not caused by any LCD/Plasma interference as I have the same issue with the lights in the kitchen and dining areas as I do in the t.v. room. In fairness, for the price they are still great value especially if used with the Varilight transformers. I have had mine for over 6 months now and haven't had to replace a single bulb yet (famous last words).
HandsomeBWonderful is offline   Reply With Quote
Old 02-09-2008, 11:54 AM   #6 (permalink)
Nope, just a CRT for day to day use and a projector for movies.
Old 02-09-2008, 11:57 AM   #7 (permalink)
Actually, that's an idea. Although I've tried different remotes all the buttons I've tested have been single-press type buttons not hold-down buttons. Maybe I'll try it again with a volume up/down button that I know works on a hold-down basis.
But that wouldn't explain why it dims perfectly on the existing button when the remote is close to the sensor.
Old 02-09-2008, 12:55 PM   #8 (permalink)
Thanks: Gave 3, Got 5
I have the same problem with mine.
cossie is offline   Reply With Quote
Old 05-09-2008, 8:58 AM   #9 (permalink)
Sounds like they are just rubbish then.
Old 05-09-2008, 1:31 PM   #10 (permalink)
Thanks: Gave 21, Got 15
I've had the same problem since updating the software on my Harmony 885. Power button works fine on/off , but I use to be able to press and hold for dimming facility, not anymore. Are others here using Harmony remotes? I've emailed Harmony but are STILL waiting for a response
scottie50 is offline   Reply With Quote
dimmers, dimming, remote, varilight
