| Re: Anyone used this wireless lighting system?
I have one. It can control 4 channels (multiple lights on each channel is possible) and have 4 scenes. The scenes dim up and down very nicely. If you set the controller to control scenes you can't control each light individually but you can dim the scene as a whole. You could have a 2nd controller set to control the individual channels but this controller can't control the scenes.
Within limits its pretty good. You can't use any other remote with it though. you would be stuck with the round one (which is basically the wall switch in a different case)
Jamie Arcam AVR200, MS 500THX Speakers, Philips 42" HD screen, PS3, Philips Pronto RU950 |
