Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
MCE Remote controlling blu-ray / HD-DVD playedalive Windows Media Center Edition MCE 0 22-01-2008 5:31 PM
Controlling a remote sky + box? gareth h Sky and Sky+ 1 10-11-2007 8:58 AM
Sky remote controlling TV? KD54 Sky and Sky+ 1 28-04-2006 3:41 PM
MCE Remote and controlling my TV gphillips Windows Media Center Edition MCE 0 07-03-2006 8:26 AM
Controlling Tv via sky remote Mad Mikeyboy Sky and Sky+ 2 25-10-2005 8:18 PM
Old 24-08-2008, 9:02 AM   #1 (permalink)
Thanks: Gave 9, Got 13
Remote controlling Gira lightning bus?
I've got Gira lightning at home, with a GIRA remote control.
Does anyone know if this can be controlled by other remotes, e.g. Pronto or anything?
Meridian 561 Processor & SB+
8 x Tag 125 Mono Blocs , Monitor Audio Studio 20s & Studio Centre, GFX Rears and REL Storm
Panasonic AE3000 (110"), Philips 37" LCD, Xbox 360, Wii & PS3
DannyBoy73 is offline   Reply With Quote
Old 25-08-2008, 9:46 PM   #2 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,332
Re: Remote controlling Gira lightning bus?
Pronto and RTi could control it as can netstreams digilinx as Gira is IIRC EIB/KNX protocol.
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
Old 26-08-2008, 8:17 AM   #3 (permalink)
Do you know if the Pronto 9600 could control it? if so, what extra bits would I need to send RF signals to control the lights?
Old 26-08-2008, 8:56 AM   #4 (permalink)
Thanks: Gave 25, Got 109
As the remote is RF then I don't think you will find any straight forward solutions for conventional remote controls. IIRC Netstreams uses a wired KNX gateway to talk to such systems, I guess Pronto & RTi could do the same using RS232-KNX gateway although it would need some custom programming to make it work. It would be easier to see if there is a Gira IR interface that will allow control of the lights from any learing IR remote control. You could try KNX suppliers such as Ivory Egg as I'm sure they could advise you on an appropriate solution or maybe some of the KNX installers on the forum could post some ideas.
neilball is offline   Reply With Quote
Old 26-08-2008, 9:27 AM   #5 (permalink)
Assured Advertiser
Would need a GIRA IP gateway and pronot script (lots of programming or an RS232 Gira interface with RFX9600 and TSU9600 and RS232 control of the Lights (less programming)
bus, controlling, gira, lightning, remote
