AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
LinkBack Thread Tools Display Modes
Old 25-05-2003, 4:03 AM   #1 (permalink)
Futronix P50 ?????
I have a single room with 7 x 50 w mains bulbs. I have been looking at Furonix to work the lights in sync with my prontp buttons. The P100 looks good but I think I want a P50. I don't need multi scene, just a simple on/off/dim. They also cope up to 600w and most importantly DON'T need the neutral wire.
Does anyone know anything about the P50?
Does anyone know where I can get a P50 from?
alistair is offline
Old 25-05-2003, 5:54 AM   #2 (permalink)
Chris Frost's Avatar
Thanks: Gave 34, Got 77
If you just need a remote controlled dimmer that can be worked from your Pronto then B&Q have just started selling these for £29. You'll also need the remote for it which is about £7.50
Regards
Chris Frost
Chris Frost is offline
Old 25-05-2003, 3:45 PM   #3 (permalink)
Thanks: Gave 1, Got 6
TLC have the full range of these dimmers Here which is where I got mine from.
Good prices and next day delivery.
KW1816 is offline
Old 25-05-2003, 3:47 PM   #4 (permalink)
Oops - Meant to say that you don't need the remote. The dimmers can be programmed to respond to any IR signal - they suggest an unused button on an existing remote.
With the Pronto I simply downloaded some IR codes for a bit of kit I DIDN'T have, and programmed the dimmers to that.
Kevin.
KW1816 is offline
Old 27-05-2003, 1:10 AM   #5 (permalink)
Thanks Chris & Kevin,
just what I needed. I'll try the TLC site first then good ol' B&Q if that doesn't work. Both seem to cope with a 400w load which suits me fine.
cheers
Alistair
alistair is offline
futronix, p50
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
