19-08-2008, 1:17 PM
#1 (permalink)
| | Senior Member
Thanks: Gave 316, Got 84 | Silent air conditioning for smallish home cinema room
Is there a silent air conditioning unit that I could use in my smallish home cinema room as it gets quite hot (especially in our humid muggy summers!). A dehumidifying type would be prefered too.
I do NOT have any windows to hang a hose out of and I don't want the unit to make any "thump" noises when it has "kicked-in". Also, it must be electrically stable and not introduce spikes or pollution into the mains.
Does anyone know of what that will suit ?
Many thanks!
M.J.
19-08-2008, 1:49 PM
#2 (permalink)
| | Assured Advertiser
Thanks: Gave 23, Got 127 | Re: Silent air conditioning for smallish home cinema room
Hello M.J.
What's the size of the room in metres x metres ?
Nothing is completely silent, there are makes that are almost silent with very low power consumption that would be perfect.
Mark.
19-08-2008, 1:52 PM
#3 (permalink)
| | Senior Member
Thanks: Gave 316, Got 84 | Re: Silent air conditioning for smallish home cinema room Quote:
Mark. |
Approx. 4m x 4m ? This is very approx., but certainly no bigger than that. Thanks.
M.J.
19-08-2008, 2:13 PM
#4 (permalink)
| | Senior Member
Originally Posted by Mark Grant Nothing is completely silent, there are makes that are almost silent with very low power consumption that would be perfect.
Mark. | Any names of brands etc ? Thanks
M.J.
19-08-2008, 3:51 PM
#5 (permalink)
| | Assured Advertiser
For a room size of about 16 square metres 2.5kw of cooling should be enough, maybe go to next size up 3.5kw to allow for extra capacity if a few people are in the room.
Daikin are the best make I have installed, very quiet, lowest power consumption and reliable. Not cheap but they are the best.
If you buy a system that does heating also (heat pump) then most of the Daikin systems have a reduced 5% VAT rate, so they cost slightly less than a cooling only system.
Daikin Part numbers for latest models would be for a 2.5kw FTXS25D indoor unit with RXS25E outdoor
For 3.5kw FTXS35D with RXS35F
There are a few aircon installers on the forum, so maybe someone local will send you a message
Mark.
20-08-2008, 12:07 PM
#6 (permalink)
| | Senior Member
Originally Posted by Mark Grant For a room size of about 16 square metres 2.5kw of cooling should be enough, maybe go to next size up 3.5kw to allow for extra capacity if a few people are in the room.
Mark. | Thanks Mark. Is there a way of doing this without an outside unit?
What does an install of a unit like the FTXS25D and RXS25E involve?
Many thanks!
M.J.
25-08-2008, 4:14 PM
#7 (permalink)
| | Member
Thanks: Gave 1, Got 5 | Re: Silent air conditioning for smallish home cinema room Quote:
Originally Posted by MJeeves Thanks Mark. Is there a way of doing this without an outside unit?
Many thanks!  |
if there is no outside unit how will the heat get out? through a vent? well then you will have the main noisy unit inside the room. Any electrical appliance with motors etc will cause electrical interfearance even your nabours houses will, but all electrical equipment should be able to filter this out, if not thens it not worth buying.
25-08-2008, 6:46 PM
#8 (permalink)
| | Senior Member
Originally Posted by rssteve if there is no outside unit how will the heat get out? through a vent? well then you will have the main noisy unit inside the room. Any electrical appliance with motors etc will cause electrical interfearance even your nabours houses will, but all electrical equipment should be able to filter this out, if not thens it not worth buying. | What about extracting the heat into the loft ?
M.J.
25-08-2008, 10:27 PM
#9 (permalink)
| | Member
Thanks: Gave 14, Got 25 | Re: Silent air conditioning for smallish home cinema room
Talking of lofts, wasn't there a system discussed on here last summer about a loft mounted system that can feed cool air to four bedrooms? ISTR that someone had two fitted, the second one to cool their cinema room and kitchen. This should be quiet as the outlet is remote from the A/C unit. Unfortunately I can't find the thread, as I would be interested in one as well.
Ian
25-08-2008, 10:52 PM
#10 (permalink)
| | Senior Member
Originally Posted by zircon3035 Talking of lofts, wasn't there a system discussed on here last summer about a loft mounted system that can feed cool air to four bedrooms? ISTR that someone had two fitted, the second one to cool their cinema room and kitchen. This should be quiet as the outlet is remote from the A/C unit. Unfortunately I can't find the thread, as I would be interested in one as well.
Ian |
Thanks.
Anyone know the thread or the model/make?
M.J.
26-08-2008, 7:07 AM
#11 (permalink)
| | New Member
IIRC it was called a lofty http://global-cooling.co.uk/ about 2/3 of the way down the page. |
27-08-2008, 11:23 AM
#12 (permalink)
| | Senior Member
Thanks.
Not cheap is it?
M.J.
13-09-2008, 11:06 AM
#13 (permalink)
| | Member
Thanks: Gave 26, Got 3 | Re: Silent air conditioning for smallish home cinema room
hi,daikin are good but the likes of fuji and mitsubushi are there equal.the lofty is a ducted unit which similar units can do the same job at a reduced cost.by the way well serviced secondhand units shouldnt be ruled out either.
samsung le52a656a lcd,meridian kit-518,596,504,568,562v2,551,dsp5000c,d600,dsp33,ps3, sky+,rel200e,htpc
