Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
get 350w dimmers mbdj0 Home Automation, Lighting, Security, Heating and Cooling 6 22-07-2007 5:43 AM
Rf Controled Dimmers TWMB Home Automation, Lighting, Security, Heating and Cooling 2 24-05-2007 4:22 PM
light dimmers zak786 Remote Controls 4 07-01-2007 8:42 PM
LED strips and dimmers TobyAnscombe Home Automation, Lighting, Security, Heating and Cooling 2 04-12-2006 8:54 PM
TLC dimmers overheating MikeRJ Home Automation, Lighting, Security, Heating and Cooling 1 24-11-2004 3:33 PM
Old 08-08-2008, 9:46 AM   #1 (permalink)
Thanks: Gave 6, Got 6
GET dimmers
Has anybody installed these
http://www.getplc.com/news/news009.asp
i thought they looked quite good but was unsure if they were any good.
trying to get some technical information about them from GET has been rather difficult. if any one uses them how are they wired up for using as a 2 way switch and multi way switching as they say that they can be dimmed form any of the switches?
i presume you would just have to put in a 3core between each switch
aberdeenpaul is offline   Reply With Quote
Old 08-08-2008, 2:07 PM   #2 (permalink)
vex
Assured Advertiser
Thanks: Gave 9, Got 181
Re: GET dimmers
Are you talking about the GET SMART range?
If so then think of them as a stripped out Rako range and your'll be fine.
THey can only control either 4 individual circuits or 4 scenes depending on how you set them up, but if you buy from the right place they can be very cost effective.
V.
Be careful out there forumites - 89% of statistics are made up.
vex is offline   Reply With Quote
dimmers
