Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
electric curtain systems lone ranger Home Cinema DIY 2 24-11-2006 9:35 PM
Cheap electric screens? djblack Home Cinema Hardware Bargains and Discount Codes 0 06-03-2005 5:27 PM
OT - double curtain tracks? richard plumb Projectors 1 29-08-2002 3:20 PM
Cheap electric screens..... JSW Projectors 5 28-05-2002 1:33 PM
Old 09-07-2008, 6:53 PM   #1 (permalink)
Tommy Angelo
Posts: n/a
Cheap electric curtain tracks?
I'm looking for a cheap way to remotely open and close curtains.
I was tempted by this Link
But because it's not IR I wouldn't be able to control it with a Logitech Harmony remote.
Any help will be much appreciated.
Old 10-07-2008, 11:30 AM   #2 (permalink)
vex
Assured Advertiser
Thanks: Gave 9, Got 181
Re: Cheap electric curtain tracks?
Personally and IMO, the words 'Cheap Automatic Curtains' would send me running to the hills.
Cheap ones never really work and even some of the better ones are anything but silent!
At least his ebay site says that he offer a full credit returns policy so it might be interesting to try these out.
V.
Be careful out there forumites - 89% of statistics are made up.
vex is offline   Reply With Quote
Old 10-07-2008, 3:25 PM   #3 (permalink)
Isco 3's Avatar
Thanks: Gave 1, Got 36
Plus the cheap ones do not have enough torque to move a heavy fabric. If you want to motorise velvet curtains or your curtain track is long, then you will need to look at the motor's torque.
Isco 3 is offline   Reply With Quote
Old 16-09-2008, 2:55 PM   #4 (permalink)
Thanks: Gave 15, Got 6
Hi Tommy Angelo
I have opened a similar thread about remote electric curtains
Did you purchase the Ebay ones in the end and if so how did you get on?
Yoghurt
yoghurt is offline   Reply With Quote
Old 17-09-2008, 11:37 PM   #5 (permalink)
Tommy Angelo
Posts: n/a
I ended up using my hands.
Sorry I can't be of more help.
Old 18-09-2008, 11:35 AM   #6 (permalink)
Thanks Tommy
Thats the conclusion I am coming to-get a professionally fitted metal curtain rail installed with a pulley system on either side of the bay.
I may then look at adding the Ebay motor system to each side at a later date
Yoghurt
Old 13-11-2008, 5:42 PM   #7 (permalink)
Electric curtains have been increasingly popular since "silent gliss" released their basic range that enables customer to fit it themselves for less than £400 (UK price). Make sure you buy the one with the timer option for automatic closure for when your on holiday,
Here are a couple of websites that will help you with electric curtains.
Hope this helps
www.electriccurtainrailstracks.co.uk
Silent Gliss Group Headquarters*>**Home
rose10 is offline   Reply With Quote
Old 14-11-2008, 9:24 AM   #8 (permalink)
Thanks Rose 10
In fact I have got a metal pulley system now installed in the bay window and just waiting for the new curtains.
I am considering the Ebay motor system at a later stage
Thanks for the advice
cheap, curtain, electric, tracks
