AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
LinkBack Thread Tools Display Modes
Old 21-02-2008, 9:36 PM   #1 (permalink)
Thanks: Gave 1, Got 0
Hot water cylinder control
Is there any product on the market that allows progammable control over the temperature of a hot water cylinder?
What I am trying to achieve is the ability to run different temperature profiles at different times of day - allowing the cylinder "on" temperature to be reduced say in the middle of the day?
sjking is offline
Old 22-02-2008, 8:53 AM   #2 (permalink)
MarkP80's Avatar
Thanks: Gave 69, Got 60
Re: Hot water cylinder control
My central heating works like you say, not the hot water. Rather than be programmed to turn on and off at different times, it is permanently on. The programmer just changes the temperature at different times of the day and weekend, so it's at say 21 on an evening, 16 during the day etc. It may be that you can do something similar. My controls are Danfoss, maybe look into their product range to see what they have?
The plumbers that did mine have a website, and one of the plumbers always mans the phone. It may be worth your while giving them a call to see if they can help -
Link
HTH,
MarkP
My Cinema and the Bar!
MarkP80 is offline
Old 27-02-2008, 1:45 PM   #3 (permalink)
njp
Thanks: Gave 68, Got 178
I imagine your rationale for wanting to do this is to reduce your energy costs, while still having hot water at the required temperature when you need it - similar to programming a room temperature profile. However, I really don't think there is any point in doing this. Provided your water cylinder is well insulated (as it should be), you might just as well switch off the water heating entirely between demand periods. The temperature will not fall significantly if no (or very little) water is being used, so no fine control is warranted.
"Climate is an ill-tempered beast, and we are poking it with sticks" - WS Broecker
Discovery of Global Warming
njp is offline
control, cylinder, hot, water
Refbacks are On
Thread Thread Starter Forum Replies Last Post
PC ULTRA CYLINDER - It's on it's way !!! jonna Subwoofers 80 13-01-2008 12:12 AM
SVS 20-39 PC-Plus Cylinder V's Monolinth fatrich Subwoofers 12 25-05-2007 9:02 PM
Where Do You Buy Distilled Water (For CPU Water Cooler)? MDPE Motherboards, CPUs, Cases and PSUs 10 24-08-2006 2:47 PM
SVS how to get a cylinder ? ARoss Subwoofers 18 04-10-2005 9:07 PM
Which SVS? Box or Cylinder? Mroizouk Subwoofers 15 28-01-2005 3:55 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
