AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
LinkBack Thread Tools Display Modes
Old 19-02-2008, 10:28 PM   #1 (permalink)
lights not working
Hi Guys.Hope someone can help.I have a hallway light and a landing light.Downstairs I have a 2 gang 2 way light switch which has 2 common terminals,2 L1 terminals and 2 L2 terminals.Upstairs I have a 1gang 2 way switch with 1 common terminal and 1 L1 and 1 L2 terminal.Wiring is as follows: down stairs 3 red,black and earth wires.Upstairs 2red, 1 black and 2 earth.
I have connected upstairs as follows:L1 black, L2 Red and common Red.
I have connected Downstairs as follows:Common:Black wire.L1 not connected.L2 red with link wire to the other common terminal.L1 red and L2 black.
The hallway light works fine but the landing light will not work from either downstairs or upstairs.HELP!!!!
matrix1 is offline
Old 19-02-2008, 10:52 PM   #2 (permalink)
Thanks: Gave 11, Got 36
Re: lights not working
Heres a quick and dirty circuit diagram that may help.
Don't assume that black wires are neutral - commonly with lighting circuits they are used as the live return - they should have red heat shrink on them to signify but they rarely do
John7 is offline
Old 20-02-2008, 1:07 AM   #3 (permalink)
Sonic67's Avatar
Thanks: Gave 523, Got 683
This might seem a little dangerous but sometimes when I haven't a clue I do this. Turn off power and disconnect everything. Get a mains tester screwdriver or similar. Don't let anyone near switches. Switch on power. Test to see which are live with screwdriver or other test equipment that can test live cables. Find out which actually are live. You shouldn't need to touch them anymore than you have to. Once you are happy what's live switch off power.
Some of your cables will be live all the time some only live when switched.
With landing lights there's different ways of wiring. It may be that a live feed is taken from the hall switch and looped across to the common on the landing switch. Then two wires go upstairs and are connected to L1 and L2. I used to call them strappers. Another live wire then goes from the common of the upstairs switch to the ceiling light.
Note regardless of colours all the wires at light switches will be live (except bare earth wires of course). It may seem that some are coloured black but that's down to the cable that was used. Sparkys only tend to use red/black cable. The black wires should really be covered with red tape to indicate live.
Neutrals are carried around the lights so aren't involved here.
Thing is this isn't the easiest to explain. Look at this:
http://en.wikipedia.org/wiki/Light_switch
If you look at the second diagram following this text:
By connecting two of these switches together back-to-back, it can be arranged that toggling either switch changes the state of the light from off to on, or on to off:
That's what I think you might have.
Shuttle PC, Toshiba 37WLT66 LCD TV, Onkyo TX-SR705 AV Amp, Cable TVDrive, Toshiba HD-E1 HD DVD player, PS3, Wii, DS Lite, PSP Slim and Lite, (and the rest of the house has a lot more)
Sonic67 is offline
lights, working
Refbacks are On
Thread Thread Starter Forum Replies Last Post
2000 Ford Focus Fog lights stopped working chedmaster Motoring 7 08-01-2008 10:07 PM
Wii-Remote: lights not working. Help wanted. Scapegoat Wii 0 30-12-2007 11:22 AM
Ceiling lights have an earth but, original lights don't marksimonwright Home Automation, Lighting, Security, Heating and Cooling 13 02-11-2007 9:24 PM
360 stopped working !!! 3 ring lights !! readbmr Xbox 360 18 13-02-2006 5:00 AM
advice needed on getting lights working with my plasma - confused ! jamieuk23 Plasma Televisions 7 24-11-2005 12:34 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
