AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
LinkBack Thread Tools Display Modes
Old 18-02-2008, 9:53 AM   #1 (permalink)
Rewiring and hanging a Ceiling light?
We live in a 2 story loft. and we have a horrible light hanging in the stairway. the only problem the top of the fixture is on the 2nd story ceiling extending down to the top of the 1st story!
Here is my solution though,
We bought a three way ceiling light fixtures and the bell lamp coverings to fit it. I'm going to take off the end of the old fixture and attach the new fixture using another chain or heck what ever will fit inside as there isn't a place for the chain to attach. Any tips?
kurapika is offline
Old 19-02-2008, 9:33 AM   #2 (permalink)
i-B
i-B's Avatar
Thanks: Gave 1, Got 3
Re: Rewiring and hanging a Ceiling light?
Hmmmm,
Can't quite picture what you are trying to do.... I'm assuming that this is an open stairwell with a light fitting on the ceiling that dangle all the way to the first storey.
First off - hire a scaffolding/access tower - it's going to cost you about £100 but it's a lot cheaper than breaking your neck, remember if you fall from 2 storeys you will be falling 20ft+ any way you look at it it's going to hurt .
Secondly (with the use of scaffolding tower ) once you get up there you will find that there 'should' be a ceiling joist in the vicinity - this can be used to secure the fixing for the light.
Thirdly - seriously consider getting an electrician (preferably one that is NICEIC registered and comes with a personal reccomendation from a friend or neighbour) to do this - this will probably cost you a couple of hundred quid but it will be worth it in the long term.
If you are still struggling (budget whatever) take some photos of the stairwell and the lamp, post them up here and I'll see if I can 'talk you through it'...
i-B (a.k.a Gavin )
I work with NICE toys
i-B is offline
ceiling, hanging, light, rewiring
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Hanging from Ceiling - no joist support!? HDTV-Stu Projection Screens 10 25-06-2006 9:50 AM
Hanging a Projector from a Plasterboard Ceiling rm48ic Home Cinema DIY 9 02-05-2006 8:05 AM
Hanging a projector screen from the ceiling doncoolio Projection Screens 5 25-07-2005 9:01 AM
Hanging Plasmas off the ceiling scarty16 Plasma Televisions 11 03-07-2003 8:36 AM
Rear sides hanging from the ceiling ? Mad Max Speakers 6 06-06-2001 3:26 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
