Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
My Living Room (2ch based) and Media Room (5.1) Systems Markie Boy Members' Home Cinema Gallery 15 13-04-2008 5:51 AM
My Living Room amills2005smart Members' Home Cinema Gallery 16 21-01-2008 1:09 PM
My living room and cinema room boardy Members' Home Cinema Gallery 8 07-09-2007 4:54 PM
My first 'living room' PC innerise Computer Systems 24 20-03-2006 11:42 AM
Fitting a projector and screen into a room. MerMan Projectors 17 28-08-2002 7:20 PM
Old 04-02-2008, 6:56 PM   #1 (permalink)
Thanks: Gave 10, Got 2
Fitting varilight in living room
hi
recently i bought a varilight dimmer 1 gang for our bedroom and it works great , very simple for me just to swap it over from my old dimmer switch
anyway ive decided id like to fit a 2 gang varilight dimmer in my front room to go with my home cinema , like this
http://www.tlc-direct.co.uk/Products/VLIQ1402.html
but unfortunatly its a little more complex than my bedroom as i have this switch fitted
the 2 switchs that are on are connected to my lighting but the 3rd switch is connected to the box on the wall (anyone know what this box is ?)
its near the ceiling and i havnt got a clue what it is ? been there since i moved here , id really like to get it blanked off but im not to sure how to blank the wiring off , any help would be great
TH42PWD7 - DVDO HD+ - VSX1015 - Media HTPC - Harmony 555
Trevor spencer is offline   Reply With Quote
Old 04-02-2008, 8:17 PM   #2 (permalink)
Thanks: Gave 25, Got 108
Re: Fitting varilight in living room
The plate with a hole looks like some kind of flex outlet, maybe used with a wall light fitting previously (or fitted in place of a wall light that was removed by the previous owner?
In any event if you isolate the power to the circuit at the fuseboard/consumer unit you can then disconnect the cables from the switch and plate and pop them into suitable terminals - simply remove them at either end one at a time so you don't get mixed up especially if there are more than one cable in a terminal. Once they are safely disconnected you can then fit you blank plate and replace the switch.
neilball is offline   Reply With Quote
Trevor spencer (05-02-2008)
Old 05-02-2008, 6:25 PM   #3 (permalink)
hi thanks , but im a little confused by "pop them into suitable terminals" as its the flex plate switch im going to struggle with , do you mean pop them into suitable terminals on the new light switch or something else sorry
also the wiring that is going to the flex plate how would i blank those wires off as they will just be dangling behind the blanking plate , i presume i wouldnt want these live anymore ?
Old 05-02-2008, 7:07 PM   #4 (permalink)
ok just had a quick peek behind the switch and ive got 1 ,2 and 3 way wires and A B C com wires (these are daisy chained up) , on the dimmer i have live and load , which wires are which as they use different names ? Thanks
fitting, living, room, varilight
