Originally Posted by ZippyCat The output from the DVR will be a composite video signal and therefore not one you can ‘tune in’ via the aerial socket and tuner. You will need to put a RCA plug onto the end you are currently plugging into aerial socket and connect this into the composite input on your TV. I'm very surprised you can see anything at the moment, as the two types of signals are incompatible with each other.
Let us know how you get on. |
Im not sure what you mean ?
can i get an RCA plug to fit onto rg59 cable.. ive never seen these ?
So is this what i need and then i will see the picture clearly ? have i dont right in using rg59 coax, surely theres a way round this for me
