Originally Posted by Da_Rude_Baboon |
Actually I have already ordered 3 of those.
However, despite getting reassurance from them that they were direct replacements, I in fact did end up needing to replace the existing transformer.
With the existing transformer, when you switched them on they flashed briefly and went out - presumably because they were not drawing enough power and the electronic transformer thought there was no load.
I replaced the transformer with one supplied by them, and they work fine. However, that added another £7 to the cost.... so not really a cost saving exercise...
On a positive note, they are very good. I used the traditional warm white so they blend in with other lights, and though not as bright as the 20w halogens they replaced they are bright enough - and cheap enough and long lasting that I can leave them on all evening, which is what I wanted.
