Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Wireless speakers for tv advice needed shoreditch Speakers 3 10-07-2007 2:38 PM
Advice/Help needed on wireless surrounds. Crabman32 Speakers 2 06-01-2007 5:26 PM
Advice needed for MP3 Home wireless system.. gp2229 How do I get the components of my home cinema to work together? 2 19-12-2006 1:04 PM
Advice With AV Control Cenres Needed Oh_Mutants Interconnects, Speaker Cables and Switches 6 21-06-2006 8:49 AM
Quick advice needed for wireless set up! addyb Xbox Live 9 09-01-2006 8:00 PM
Old 01-02-2008, 12:57 PM   #1 (permalink)
Thanks: Gave 138, Got 251
Wireless control advice needed
I want to be able to replace my room thermostat with a device that will allow me to program on/off and temperature times from the internet without having a PC turned on.
Unfortunately neither the location of the boiler, thermostat or intervening wires are easily connectable to the router using ethernet cabling or ethernet over mains so I would like a solution that uses wireless, preferably with something I can just replace the Honeywell with and maybe a seperate unit connected to the router.
I have found the Heatmiser Netmonitor that will plug into my ADSL router but that system seems to only then offer a hard wired connection to the thermostat.
Does anyone know of a wireless solution that can connect to my router but doesn't need a PC?
All that is necessary for the triumph of evil is that good men do nothing. attributed to Edmund Burke.
Philips 37PF9830, Denon AVR4306, Panasonic NV-HD660B, Philips N1700, Xbox360, Technics SP25, Sony CDP-CX450, Sony CDP-CX455, SkyHD, Nokia N95 8GB
andykn is offline   Reply With Quote
Old 01-02-2008, 10:24 PM   #2 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,331
Re: Wireless control advice needed
Honeywell Hometronic
http://www.sensibleheat.com/how-does-it-work.html
Wireless control with a web interface, will do everything you need
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
Old 04-02-2008, 11:58 PM   #3 (permalink)
Hi, thanks very much for the response.
I had already looked at the Honeywell system; but Sensible Heat seems to be the only way to purchase it in this country and they didn't seem to think my email enquiry worth responding to. Technical information is difficult to come by too.
From my researches, the home automation industry seems years behind current technology - both AMX and Crestron require an untidy chain of modules for this quite simple requirement. Crestron don't even publish a dealer list.
Might have to keep my money in my pocket for a few years.
Old 05-02-2008, 9:00 AM   #4 (permalink)
Thanks: Gave 25, Got 108
If you've not seen any of my previous posts you might not know that I work for Sensible Heat - I run their Scottish/Northern England office
Honeywell have a dedicated Hometronic website and you can download the R4 manual from there. Note that the R4 manual does not include absolutely every application or some of the newer modules but the descriptions of control strategy are correct.
When did you send in the email and which was it using the link on the website? We would normally respond to email enquiries the same day and either email or post out our brochure. If you PM me your enquiry I will make sure it gets dealt with.
In the meantime feel free to PM me with any technical questions and I'll do what I can to help.
neilball is offline   Reply With Quote
Old 05-02-2008, 9:38 AM   #5 (permalink)
Regarding Crestron, AMX and similar systems they were designed originally as a high spec, customisable user interface to sit on top of the various hardware units/platforms that required to have integrated control. In the past this made good sense - a variety of dedicated sub-systems could be used (HVAC, lighting, security, cctv etc) and all ran independently such that a failure in one sub-system or in the integration layer did not stop the other sub-systems from operating. The dedicated sub-systems were designed just for their own application so were generally robust & well tested.
Now Crestron & others have introduced their own hardware to cary out some of these functions directly, T-Stats, dimmers, amplifiers etc. However what you don't get is the fully developed control strategies to do the more complex things that many dedicated sub-systems do as standard. If the Crestron (or systems integrator) has the programming ability and fully understands the application then they may be able to replicate some or most of these control strategies but it can be incredibly difficult to design, code reliably, test and document. It can then be even more difficult to get support at some later stage if the original programmer is unavailable as someone else has to try and interpret the code - this is always an issue with any fully programmable system, affects BMS systems just as much as Crestron and others. So the options are to use the dedicated sub-systems designed for there application and use Crestron (or others) as an integration tool or try and use Crestron as a generic control system and code for the applications.
Old 05-02-2008, 3:27 PM   #6 (permalink)
Thanks for your reply Neil. I have pm'd you with a copy of my email.
I have the Hometronic R4 catalogue, but can't quite tell how easy it it to replace my current thermostat with one I can wirelessly control from the internet. I think I need a HCM200t controller (located near my router) with an HCU 30 (so I can set the temperature without having to use the controller) and an HS30 to switch the boiler.
I wasn't too frightened by the Crestron programming, I work in IT and know a couple of Crestron programmers in the AV industry - it was more that it appeared to need 4 boxes to achieve what should need only 2.
Old 05-02-2008, 5:11 PM   #7 (permalink)
Andy, you have a PM
In Hometronic land for a single zone system you would need a Manager and power supply, Room Sensor, Boiler Relay and a Web Manager. While the R4 manual is useful it is a few years old and many of the modules have been updated since and some new modules are not listed at all! You will not find any mention of the Web Manager, this is a brand new piece of kit from Sensible Heat as Honeywell do not have any native network-capable modules for Hometronic. The new Web Manager allows all of the user functions to be carried out using any suitable browser-based device and would be the only part of the system that needed to be next to your router assuming you don't want to use powerline networking products to bridge between 2 locations.
So Hometronic can meet your needs and requirements (specifically as it uses wirless comms) but it does not come cheap. It would not cost a huge amount more to zone your heating (using the Radiator Controllers) and have much better control and this would also make better use of the capabilities of the Hometronic package.
As I mention in my PM there are no other wireless stat systems I'm aware of that have ethernet networking/webservers built-in. There are some wired systems that operate over a comms bus and have software to allow central control from a PC but ths means running cables & therefore some disruption to install.
Old 14-02-2008, 2:44 PM   #8 (permalink)
Thanks to Neil for his help.
It does appear that no-one else offers this type of solution, indeed that's why Sensible Heat have had to design and build their own web controller for the Honeywell system and hence why it's not really economical for my one zone requirement (I only have a modest 2 bed flat).
Having researched myself a bit more, no-one seems to make a battery operated wirelessly controllable thermostat that can be dropped in to replace an existing thermostat. The closest I can find is the RF 210, but that needs a separate boiler switch and can only be controlled by PCs or Marmitek controllers, which, in turn, only have phone remote access, not ethernet.
All the other remotely controllable thermostats that I can find, even from the likes of Crestron and AMX either require power, wired data connections or more than 2 wire control of the boiler.
neilball (14-02-2008)
Old 14-02-2008, 5:01 PM   #9 (permalink)
Isco 3's Avatar
Thanks: Gave 1, Got 36
Hi Neil,
system is working fine!
Any news on the updated Netstreams driver?
Isco 3 is offline   Reply With Quote
Old 14-02-2008, 5:04 PM   #10 (permalink)
Hi Dimitri
Updated Netstreams driver is being tested on a couple sites right now, should be signed off by InVision in a week or two if all goes to plan. I'll give you a call as soon as it is ready
Old 21-05-2009, 7:18 PM   #11 (permalink)
I know this is over a year since the last post but another way around this would be to connect a wireless bridge to the netmiser solving your problem!
noel-pilot is offline   Reply With Quote
advice, control, needed, wireless
