Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Pronto RU950 Laingy Remote Controls 1 02-09-2004 11:48 AM
PRONTO RU950 and SKY+ milanlad Remote Controls 1 09-01-2004 8:25 PM
Trying to buy a Pronto RU950! smallman28 Remote Controls 1 21-09-2003 10:55 AM
Pronto RU950 taimur Remote Controls 9 12-09-2003 4:58 PM
Old 24-01-2008, 11:15 PM   #1 (permalink)
Thanks: Gave 11, Got 6
RF on Pronto RU950
Hi All,
Wasn't sure where if to post here or in the automation so thought I'd try here first.
I have a RU950 and I beleive it has RF built in (tell me if I'm wrong!!). I want to purchase a Clipsal Ulti 2 RF (http://www.ulti.biz/) light to replace the IR dimmer I have now beacause I want to be able to set scenes (and also because my cats collar is Infrared and when she comes through the cat flap it is in direct sight of the dimmer and they switch the lights on or off!!)
Can you tell me if it is possible to control this unit directly from the pronto and if not what other equipment I would need to allow me to do this.
I'm open to suggestions on other ways of doing it.
Dan
Panasonic TH-42PZ70 (On-Wall), Panasonic DMP-BD55, Onkyo TX-SR806, Monitor Audio GS10's on Partington Super Dreadnoughts, Wharfedale Diamond 9.CS, Wharfedale Diamond 9.DFS, BK Monolith DF, Philips Pronto RU950, IXOS & QED Cables, PlayStation 3, All kit sitting pretty on Partington Minim AV
dplayer is offline   Reply With Quote
Old 25-01-2008, 12:54 PM   #2 (permalink)
Re: RF on Pronto RU950
Moderator - Please can you move this to Automation
Old 25-01-2008, 10:45 PM   #3 (permalink)
Thanks: Gave 7, Got 82
I think the RF on most pronto's except the very latest is only to comunicate with an IR extender philips also make ( see here http://www.letsautomate.com/10921.cfm ). I have a TSU7000 and thats all it does on that model.
kevlar is offline   Reply With Quote
dplayer (25-01-2008)
Old 26-02-2008, 12:10 AM   #4 (permalink)
JimBobVFR400's Avatar
Thanks: Gave 22, Got 224
Quite correct, in a sense.
It is possible to use the RF in other ways though:
  • X10 - The RF frequency is the same as the RF used by the X10 RF receiver (can't remember the name of it) and you can use a program called Godegen to generate the appropriate Pronto Hex codes to directly control this via RF
  • The pronto sends the IR code as RF (with some added bits on the front to denote extender address so you can use more than one extender) so in theory if you can get something to receive the RF and retransmit as IR then this can be learnt by the pront, switch it to rebroadcast this as RF and Bobs you uncle. I've successfully used the RF receiver/IR transmitter half of a powermid to learn the RF for some cheapie plug in RF remote sockets using this technique, its a bit hit and miss and did take some perseverance but it did work eventually. As a bonus the powermid will also work as a simple Rf extender with the prono in RF mode and cost a tenner from E-bay
The above depends on the frequency of the original RF remote (can't remember the pronto frequency off the top of my head) but it MIGHT be technically possible to learn your RF remotes codes
JimBobVFR400 is offline   Reply With Quote
pronto, ru950
