AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
LinkBack Thread Tools Display Modes
Old 22-01-2008, 1:12 PM   #1 (permalink)
Lighting wiring - fairly basic stuff
I need to replace the lighting unit in my home cinema but need some guidance on the wiring. After removing the current fixture, I can see 3 live wires, 3 netral wires and two earths however my new fixture only has a connection for 1 of each.
Presumably there is some sort of loop going on and i will need to determine which is the live live. Once I've done this however, how should I connect all the wires?
Many thanks
dunlop49 is offline
Old 22-01-2008, 2:29 PM   #2 (permalink)
Thanks: Gave 21, Got 67
Re: Lighting wiring - fairly basic stuff
Your lighting is wired on a ring, sometimes called loop-in. There will be an incomin & outgoing live-neutral-earth cable which feeds power to the lighting point in each room. The 3rd cable is the switch wire taking power down to the switch and a return feed which is wired to the light. So the ring and feed to the switch is always powered unless you turn off the MCB or remove the fuse feeding the lighting circuit. The switched live return feed is only live when the switch is "on". So for the light fitting to operate it needs to be connected to the switched live from the switch plus neutral and possible earth depending on whether your chosen light fitting is double insulated or not.
I'm guessing from your post that you are taking down the existing fitting and removing the ceiling rose/junction box that terminates all of the existing cables. You will need to get a suitable junction box that can be placed into the ceiling void and safely replicate the exising lighitn connections. You will then have a single cable from the new junction box feeding your new light fitting.
If you are at all unsure about the wiring or the process to safely reconnect all of the cables for the new fitting then please call in an electrician or at least a competent friend to make sure it is done correctly.
neilball is offline
Old 22-01-2008, 3:02 PM   #3 (permalink)
Great thanks.
My only issue is that I have already taken out the wiring from the old junction box so i have nothing to replicate?
dunlop49 is offline
Old 22-01-2008, 3:45 PM   #4 (permalink)
Ah, that makes things a little more complicated! If you have not already made the cables safe then please shut off the power to the lighting circuit back at your consumer unit or fuse box.
I had a quick google and found this page which explains about loop-in lighting circuits. I is reasonably detailed and has some useful diagrams so take a look through and make sure you are familiar with the process before continuing.
First things first I would get some suitably rated choc-block type connector strip and safely terminate the cables into individual blocks - you might want to separate each block of 3 connectors so each cable can hang freely from the ceiling. That makes sure everything is safe for now.
Do you have a multimeter with a continuity setting? If so AND WITH THE POWER STILL OFF, put the light switch on and test for continuity between the Brown/Blue or Red/Black cores on each cable. When you find the cable that shows continuity then that will be your switch cable and can be labelled accordingly. The other 2 cables will be the lighting ring so again label these for ease of identification.
You can then source a suitable junction box, terminals and some earth sleeving if you need it and the cables should be connected as follows:
  1. the Live, Neutral & Earth for the lighting ring cables need to be connected together: Live to Live, Neutral to Neutral, Earth to Earth.
  2. the Red or Brown core on the switch cable need to be connected to the Live terminal of the lighting ring. This is the live feed to the switch.
  3. the Black or Blue core needs a red sleeve and should be connected into a separate terminal, this is the live feed back from the switch.
  4. your new length of flex of cable for the light fitting needs to have the Live connection in the fitting connected to the live feed back from the switch (Black or Blue core sleeved red), Neutral in the fitting connected to the Neutrals for the lighting ring, Earth in the fitting connected to the Earths for the lighting ring. This assumes that the switch cable does not have an earth fitted currently.
Have a last check of the wiring to make sure the cabling is as it should be and all connections are secure. You can now put the power back on and test the new fitting turns on & off at the switch.
neilball is offline
Old 22-01-2008, 5:55 PM   #5 (permalink)
Thnaks a lot. i'll give it a go tonight
dunlop49 is offline
basic, fairly, lighting, stuff, wiring
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Lighting Structured vs mains wiring futureproof Home Automation, Lighting, Security, Heating and Cooling 3 03-07-2006 6:04 PM
Wiring for Sky Basic Service Telecom Andy Sky and Sky+ 4 17-05-2006 10:14 AM
need a little advice regards to basic lighting - transformers etc jamieuk23 Home Cinema DIY 5 20-11-2005 7:26 PM
Dedicated cinema basic lighting advice wanted . Timmy C Home Automation, Lighting, Security, Heating and Cooling 2 29-09-2005 8:47 PM
Lighting (wiring) question fufna Home Automation, Lighting, Security, Heating and Cooling 9 09-11-2003 2:35 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
