I want to change my standard on/off switch to a dimmer type one. I have been looking around and have not had too much luck. Ideally, i want one the touch sensitive ones
Does anybody have any experiences of them, are they reliable and good quality compared to the normal dimmer switches?
I have seen the following on ebay:
http://cgi.ebay.co.uk/NEW-2-GANG-MAT...QQcmdZViewItem
Does anybody have anything similar to this switch? Or do people have any other recommendations on what kind of switch i could use?
I am also thinking of buying the remote control to go with the switch, although, on the listing, it says i can use another remote. Does anybody know if my Denon remote (AVR-3805) can be programmed to use with the lights?
Thanks in advance for your help!!
