Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
HELP: Purchasing Part Of A Home Cinema Package Energy_C Speakers 5 19-12-2006 6:27 PM
Home Cinema Help - Part Deux cerbera1 AV Amplifiers and Receivers 3 05-09-2006 10:46 AM
Wireless video sender as part of home network - does such a gadget exist? moid Networking and NAS 6 26-11-2005 11:04 AM
KEF Cresta 2's part of home cinema setup? Jonathan Gray Speakers 3 26-11-2002 12:50 PM
Old 18-01-2008, 1:47 PM   #1 (permalink)
Thanks: Gave 10, Got 4
Part P / Home Network
Apologies if this is in the wrong section, I'm sure it must have been asked before but havn't been able to find anything similar using the search facility.
I've been granted planning permission for an extension and my neighbours are causing me some grief over it, they told the council that I've already started and I've removed the chimney breast etc.. Anyway, thats all untrue.
The council want to come and just check for themselves, so onto my question, the letter from the council mentions about all wiring should be Part P compilant. Everything is but I've recently just started wiring the house with cat5 and ct100 for a home network and to pipe tv around. I have a node0 in the garage where everyhing runs from. Does this kind of wiring fall under Part P ? I thought low voltage didn't ?
Is there anything else I should be concerned about ?
Any advice would be great.
Many Thanks,
Marvin
Panasonic PWD8, Yamaha RX-V757SE, Sony DVP-S725, Sky+, 3 Canton CD360F's LCR, Canton CD310F rears, SVS PB10-ISD
marvinwright1 is offline   Reply With Quote
Old 18-01-2008, 4:31 PM   #2 (permalink)
Johnny Thunder's Avatar
Thanks: Gave 236, Got 148
Re: Part P / Home Network
It doesn't mate.
Don't worry.
Johnny Thunder is offline   Reply With Quote
marvinwright1 (18-01-2008)
Old 18-01-2008, 4:59 PM   #3 (permalink)
great, thats a relief.
I didn't think it was but thought I better check.
Marvin.
Old 18-01-2008, 9:58 PM   #4 (permalink)
Thanks: Gave 1, Got 2
Marvin,
Just for your info, unless you are planning on putting a kitchen, bathroom or boiler in your extension then your wiring doesn't come under part p of the building regulations either.
All of your wiring will have to meet current wiring regs (16th or 17th edition) dependant on when you start the extension, but so long as you use a reliable contractor who is NICEIC registered you'll be fine.
Building control will require a test certificate when it's all finished, but they don't need to inspect it.
In fact if you get a decent building control officer (like the one we've got for doing my mates extension) there are only a certain number of visits required, display competence and they leave you alone.
Good luck with the build
Orfink69 is offline   Reply With Quote
Old 18-01-2008, 10:22 PM   #5 (permalink)
Thanks: Gave 2, Got 0
Originally Posted by Orfink69 View Post
Marvin,
It does not just have to be an NICEIC registerd person, saying that will get the back up of many..There are other and much better schemes such as Napit, Elecsa....If you use a contractor you just need to make sure he is part p registerd, that is all.
Alexg is offline   Reply With Quote
home, network, part
