Ok, where to start!!
I am looking to start some X10 home automation (assuming that is my best option). Currently my only requirements are as follows..
Controlled via IR (Logitech Harmony 880)
Able to dim my main ceiling light in the lounge
Able to dim my plug in lamp in the lounge
Now I am reading that IR is possible with X10 via an additional gadget. I also read that dimming both those lights is possible. Now the things that confuse me somewhat.
I WILL NOT screw one of those nasty white X10 dimmers to my wall
Now, I have seen micro modules?? which appear to wire in behind the switch on the wall and can be wired into a "momentary action switch" so that on / off and dimming is still available locally at the switch.
- What is a momentary action switch?! Can someone point me to where I may purchase a momentary action dimmer switch which these micro modules could be wired to..
- Is what Im talking about actually possible?..
- What modules are actually required to do this, and what IR module do I buy?
Any help would greatly help my karma right now!
Thanks!
