Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 29-12-2007, 12:52 PM   #1 (permalink)
Thanks: Gave 17, Got 8
X10 mk II
Happy New Year to All
Has anybody had any experience with X10 mark II. Is it any better?
Fulltopuk
Fulltopuk is offline   Reply With Quote
Old 03-01-2008, 2:00 PM   #2 (permalink)
Thanks: Gave 2, Got 34
Re: X10 mk II
I have a lot of X10-2 modules from Kevin Lo.
And yes, they are quicker to respond and much more reliable than Marmitek's old products.
The light switches are a lot of stylish too.
HIHs.
wywywywy is offline   Reply With Quote
Fulltopuk (03-01-2008)
Old 04-01-2008, 9:13 AM   #3 (permalink)
dunks517's Avatar
Thanks: Gave 360, Got 283
Re: X10 mk II
I also have some of Kevin Lo's X10 mk2 modules, they are almost identical to the Domia modules on the simplyautomate site.
http://x10-hk.com/store/product_info...products_id=44
http://www.simplyautomate.co.uk/prod...sp?prodId=6535
When the order from Kevin Lo arived in the UK I had to pay a £25.00 customs charge on around £100 worth of modules. So it may be easier to go with SimplyAutomate.
Assorted gear: Panny 42TH PX70, B&W Speakers, Kef HTB 2 Sub, Linn Diskreet speakers, multiroom Sky+ HD, PS3, Tosh EP30 HDDVD, Acer iDea 500 HTPC, Sennheiser HDR-120s, network gubbins, Xbox360s, Wii, Harmony 525, 360 & One.
My Av-centric home
dunks517 is offline   Reply With Quote
Old 06-01-2008, 2:39 PM   #4 (permalink)
Thanks: Gave 21, Got 27
Re: X10 mk II
Thanks guys, never knew there was a second gen of X10 until I read this post, must check 'em out.
Pajo is offline   Reply With Quote
Old 06-01-2008, 4:03 PM   #5 (permalink)
dunks517's Avatar
Re: X10 mk II
The only real difference is that they have a 'soft' on and off ie they dim to bright and they remember the last dim setting.
My Av-centric home
Old 06-01-2008, 6:05 PM   #6 (permalink)
Re: X10 mk II
I mean, do they work any better, with my current X10s, you have to walk to the location to see if they actually came on, which somewhat defeats the purpose.
Old 06-01-2008, 7:45 PM   #7 (permalink)
dunks517's Avatar
Re: X10 mk II
I have a mixture of X10 and X10 Mk2, the only time really when something doesn't happen is when the PC & harmony set a light scene and the CM12U disabled itself! I have had to reinstall Harmony and despite repeated requests for a new activation code none has been forthcoming. I had the Harmony MCE addon but by the time you went to the programm you were quicker getting up or reaching for the remote. I have 2 X10 Transievers around the house to widen the coverage area, on the whole I'm happy with it.
My Av-centric home
Old 06-01-2008, 8:04 PM   #8 (permalink)
Re: X10 mk II
Well I'm not so happy with mine (all X10 Mk1), with IR343 and two transcievers, and basically I could never depend on it doing what its supposed to. Probably down to all the other crap, I have plugged in.
Am considering some zwaves, but will have to read up a bit, to see are they reliable.
Old 06-01-2008, 8:52 PM   #9 (permalink)
dunks517's Avatar
Re: X10 mk II
I dont use a 343 - thats the keyfob isn't it? I use the HR10 RF Remote control and it works well. The batteries are due for a change and they have been in six months!
This is it on the left (note that the Harmony remote can also be used in conjunction with an IR 7243 IR controller):
My Av-centric home
Old 06-01-2008, 10:26 PM   #10 (permalink)
Re: X10 mk II
Sorry typo m8, meant ir543, and I also use the HR10 RF Remote control, which like you say works pretty good, better than the ir543 anyway. I am using mainly a Pronto 950 as my remote, like I said, if one can't be pretty certain that the command has been executed then the system falls on its face, and I'm never "pretty certain"
Old 07-01-2008, 10:37 AM   #11 (permalink)
Re: X10 mk II
They also are quite a bit more reliable, and have filter built into each module.
All the plug-in modules have a local button to switch on/off.
dunks517 (07-01-2008)
Old 09-01-2008, 11:59 PM   #12 (permalink)
thudspud's Avatar
Thanks: Gave 17, Got 49
Re: X10 mk II
Just got a couple of the X10-2 lamp modules today from letsautomate, Only bought them for the soft start function, very nice to not have all the lamps come on at full brightness, especilly after sitting in the dark watching a film for 2 hours. Quite like how you address them as well although will miss the rotarty wheels as it is handy when I forget what is what I have so many around the house now!
Had them not respond a few times tonight though while playing around, never had that with my older ones, also the dimming of them isn't as smooth as on the old ones, seems to drop down two distinct steps for each press of the dim button.
Panasonic TH58-PZ800
Onkyo TX-SR875, Sony BDP-350 Blu-ray, Sky HD, Squeezebox 2 + Boom, PS3, Wii, XBox360 + HD-DVD Drive
Mission 783 (Front), B&W HTM62 (Centre), Mission 782 (Rears), V6AS (Sub) All wired with QED Silver Anniversary
thudspud is offline   Reply With Quote
Old 14-01-2008, 4:08 PM   #13 (permalink)
Thanks: Gave 12, Got 11
Re: X10 mk II
Can anyone confirm if the X10 mark2 can be controlled by a Harmony 525 ?
Id like one of the lamp control units.
Onkyo 605, Q-Accoustics 5.1, Sony 250GB PS3, psn ashber100, Tosh 32WL56, Tosh RDXS34, Standard sky, Bt Vison (poo), Bt Home hub, Harmony 525, 60gig iPod video & dock.
And all connected together by wet string (albeit expensive string) !
podhead is offline   Reply With Quote
Old 14-01-2008, 7:00 PM   #14 (permalink)
dunks517's Avatar
Re: X10 mk II
The 525 remote can control an IR to X10 receiver I think its called the IR-7423? You will need to set a sequence in an activity ie house code then unit code and set the activity to leave the other devices alone.
My Av-centric home
podhead (14-01-2008)
x10
