29-12-2007, 10:45 AM
#1 (permalink)
| | Member
Thanks: Gave 79, Got 26 | Cost to set-up my Nevo SL
Im not sure this is in the right section, I will move if not.
Anyway I have partially set up my Nevo to control Sky HD, Plasma, DVD and Amp, what I need is for the Nevo to be configured to my network so I can access music and so forth and for my original settings to be tweeked a little.
What is this likley to cost and who can do it?
I am in Bebington on the Wirral.
Thanks for your help, Nik
__________________ Pioneer KRP-500a ISF'ed - Arcam AVR350 - M&K MP150's - M&K SS150's - SVS PB-13 Ultra - SVS AS-EQ1 - Sky HD - PS3 |
29-12-2007, 10:53 AM
#2 (permalink)
| | Senior Member
Thanks: Gave 224, Got 98 | Re: Cost to set-up my Nevo SL Quote:
Originally Posted by Nik555 Im not sure this is in the right section, I will move if not.
Thanks for your help, Nik | As for who can do it, I would go to a local AV Installer, as for cost, it's difficult to say but work on £40 an hour (whoever does it will need to visit your home) I would allow 3 - 4 hours. e.g. approx £160, although, I would expect a minimum charge of £200.
Good luck and, can you post back here on how long it did actually take and how much it cost.
I'm interested as I have a Nevo SL (still in it's box with extender) a Philips TSU9400 still in its box with extender). Currently using a Harmony 895 (it's the only one I actually have had the time to set up (I would'nt use the word program)
Mark
07-02-2008, 1:25 AM
#3 (permalink)
| | Member
Join Date: Dec 2003 Location: drogheda, co louth,ireland
Thanks: Gave 9, Got 7 | Re: Cost to set-up my Nevo SL
any update on this?
brendan
07-02-2008, 6:04 AM
#4 (permalink)
| | Prominent Member
Thanks: Gave 5, Got 166 | Re: Cost to set-up my Nevo SL
I have a nevo sl and would be intersted in getting it programed
__________________ Steve
kit:-Panasonic TH-50PF10,Lumagen Radiance XD,Onkyo PR-SC886 ,Nad M25,Tosh SD9500 ,Tosh EP35,Samsung BD-P1500,SKYHD,Xbox 360,PS3,M&K THX S150's/SS150's,SVS pb12-plus/2 subwoofer
07-02-2008, 6:47 AM
#5 (permalink)
| | Ex Member
Thanks: Gave 26, Got 493 | Re: Cost to set-up my Nevo SL
Getting it programmed is one thing, getting it to talk to your PC on the network is another thing entirely. It might take 20 minutes or it might never happen, you might need to replace your router.
