CCTV: Long cable runs
I'm currently installing 4 CCTV cameras around my home. The plan is to connect these to my PC Server by way of a multi-channel DVR Card.
The cameras are excellant quality (in my opinion) and when connected to the DVR card via short cable lengths give a near perfect results.
Two of the cameras wil be positioned a fair distance from the PC Server containing the DVR Card, leading to cable runs of approx. 35-40 meters.
I have purchased 2 x 50m CCTV extension cables (video, audio & power)
Trialling these prior to install I find that the picture quality degrades to an unacceptable level, and I get two horizontal fuzzy bands about 1/3 & 2/3 up the screen.
Not only does this make the recorded image of little use, but it also does not allow the motion detection software to do its job, as it is always sensing motion.
Having done a little searching I can see there are coaxial and Cat5 options for me to persue. And it seems that I could send power down the Cat5 as well.
However, I don't wish to just purchase another solution without some confidence that it will give me what I require.
So, any ideas of the "best" solution for up to 40m CCTV (Video & Audio), prefereably incl. power to avoid separate cable runs for power.
Thanks in advance.
Edit: On consideration, I really do not require the audio signal. I'm therefore looking to carry the video and, if possible, the power for the 40m cable route.
